Go Back   Home > Forums > Design & Build > Parts
Parts Where to get, and how to make the best bits. PCB's, caps, transformers, etc.
Old 2nd September 2004, 01:11 AM   #1
cowanrg is offline cowanrg  United States
cowanrg's Avatar
Send a message via AIM to cowanrg
Default vu meter help
i was at my local electronics surplus shop today and picked up a couple VU meters (they were new and $2, so why not, i need some for the alephs anyways).
well, they have a scale that on the top reads 1 - 100, then to the right of that, a red scale. the bottom readings are -20 to -1, then in the red zone, its +1, +2, and +3.
the brand is modutec, but i dont see a model # and couldnt find one on a website. does anyone know how these things work, or what they measure? can i use it? if not, someone can buy them off me, or i can return them.
edit:
i looked on digikey, and one JUST like it (cant tell if its the same because i dont have this model #), sells for $29 each. so a good deal if i cant get them to work.
Old 2nd September 2004, 01:33 AM   #2
Mr Evil is offline Mr Evil  United Kingdom
I have a circuit for driving a VU meter like the one you describe on my site (under electronics->VU meter), built from information gleaned from this page..
They're pretty simple really: They measure the level of an audio signal, calibrated in a way that is designed to correspond to our subjective perception of loudness. Drive them by rectifying and smoothing the audio signal.
https://mrevil.asvachin.eu/
Old 2nd September 2004, 01:40 AM   #3
cowanrg's Avatar
this is simply for cosmetics and i dont care about accuracy, i just want a bouncing needle that goes to the music.
it looks like the first example, (figure 1), can be made with a diode bridge and a cap? if this is the case, i can toss one of those together really quick.
Old 2nd September 2004, 01:46 AM   #4
In that case you could go even simpler and use a single diode rectifier, as often seen in cheap tape decks.
Old 2nd September 2004, 01:47 AM   #5
cowanrg's Avatar
ah ok. so it just wants to see a DC feed then? not ac?
Old 2nd September 2004, 01:54 AM   #6
Yeah, just DC.
Old 2nd September 2004, 02:12 AM   #7
cowanrg's Avatar
ok cool.
how do i trim or increase the input? i assume i can trim it by changing the resistor value, but can i increase the input, so its MORE sensitive.
Old 2nd September 2004, 02:25 AM   #8
A full-wave rectifier will be more sensitive than a single diode. If you need more than that then you'll have to use some sort of gain stage... probably an op-amp or transistor. Or you might be able to use a small transformer if the source can handle the load.
It might not be necessary though. The ones I have show full scale deflection at a mere 240mV, which a line level input should be able to provide.
Old 2nd September 2004, 02:29 AM   #9
cowanrg's Avatar
i plugged it in, using a 600V bridge rectifier i had laying around, and it appeared to work fine. it was maybe a bit TOO sensitive. so a guess a resistor could help.
does this circuit, being that it's in the signal path hurt the music any amount? if i throw a whole circuit in there im sure it could, but with just a resistor, the meter and the rectifier, how bad can it hurt it? (im planning on maybe having a switch that switches it in and out of the signal path).
Old 2nd September 2004, 02:34 AM   #10
That depends on how good the source is. The current drawn will be non-linear, which could theoretically cause problems, but I don't think it would matter in most cases. You'll have the chance to test it, so you can tell me!
car RPM meter 2 ido2 Everything Else 2 11th September 2007 08:36 AM
how to make this esr meter work with 250uA Panel meter dytln_02 Everything Else 2 27th January 2007 10:13 PM
inductance meter from a cheap meter? jarthel Parts 3 22nd September 2006 05:37 AM
Making a milliAmp meter, become a Volt meter redrabbit Power Supplies 11 26th May 2006 07:51 PM
t-amp vu meter and volt meter question.... rectaacies Class D 7 3rd February 2006 11:22 AM
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2013 DragonByte Technologies Ltd. (Resources saved on this page: MySQL 30.00%)
Copyright ©1999-2013 diyAudio
