Go Back   Home > Forums > Design & Build > Parts
Parts Where to get, and how to make the best bits. PCB's, caps, transformers, etc.
Old 2nd September 2004, 02:44 AM   #11
cowanrg is offline cowanrg  United States
cowanrg's Avatar
Send a message via AIM to cowanrg
hum ok.
well, this will be a nice system. i already have like $15k worth of stuff in that system, so its got great resolution. i guess for reference listening, i could always turn it off.
Old 2nd September 2004, 05:13 AM   #12
sam9 is offline sam9  United States
sam9's Avatar
does this circuit, being that it's in the signal path hurt the music any amount?
I may be totally wrong on this, but if you were to use a voltage divider to tap off a few mV at the output, it seems to me this would have less chance of a sonic impact than at the input where any disturbance is subsequently amplified. Acuracy might be less since one leg of the divider is the speaker load which is a varying impedance; hence the reading could vary by spectral content even is average votage was constant- but then you said you were not that interested in accuracy anyway.
Old 2nd September 2004, 05:21 AM   #13
cowanrg's Avatar
hum, i didnt realize i was supposed to use this at the INPUT. i was using it on the speaker outs. same place where speakers get connected... worked fine. i can use it at line level as well?
car RPM meter 2 ido2 Everything Else 2 11th September 2007 08:36 AM
how to make this esr meter work with 250uA Panel meter dytln_02 Everything Else 2 27th January 2007 10:13 PM
inductance meter from a cheap meter? jarthel Parts 3 22nd September 2006 05:37 AM
Making a milliAmp meter, become a Volt meter redrabbit Power Supplies 11 26th May 2006 07:51 PM
t-amp vu meter and volt meter question.... rectaacies Class D 7 3rd February 2006 11:22 AM
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2013 DragonByte Technologies Ltd. (Resources saved on this page: MySQL 30.00%)
Copyright ©1999-2013 diyAudio
