| Parts Where to get, and how to make the best bits. PCB's, caps, transformers, etc. |
I just removed the original LF353N from my Theta Pro Basic 3 DAC and replaced with DIP adapter and OPA2604. The improvement is amazing, everything just become more 3D and realistic. However, when playing female vocals, at very very extreme high notes, I hear some noise; the noise sound like what you will get when you have input overload but very brief. When the high notes come down, the noise goes away. I replaced the OPA2604 with OP275, OPA2111 and the noise still exist. I played the CD in my friend's DAC and couldn't hear the noise so I know it's not the CD. Can anyone give me some idea what's could go wrong?
Here's what I get out of the circuit following the traces. I/V -> Buffer -> some kind of filter which feeds back to I/V AD841 -> LM6321 -> LM353 (Original) AD841 -> LM6321 -> OPA2604 Thank you for your input. |
#2 |
Just found out more info....
I/V -> Buffer -> DC Servo AD841 -> LM6321 -> OPA2604 The I/V has a 5K + 470n in the feedback Output of I/V feeds through a 1.5k resistor to LM6321 DC Servo consist of 47uf/47.5K looping output of LM6321 and input of AD841 Can anyone suggest a solution to eliminate the extreme high female vocal frequency noise? |
#3 |
propably your 2-604 is too slow for the servo, thus the problem in the high freq.s. you could use sth like op27 instead or something in the range..
i am currently using 60,000 uF of capacitance in my preamplifier.. |
| Theta Data III loading problem solved | Dr.H | Digital Source | 1 | 15th May 2010 10:27 PM |
| Theta Amp problem | ZZZDave | Tubes / Valves | 8 | 29th April 2009 03:03 PM |
| opamp problem | sparkle | Solid State | 12 | 5th June 2006 12:40 AM |
| Help please - Theta transport problem | hihopes | Digital Source | 0 | 23rd December 2004 08:52 PM |
| Help please - Theta Transport problem | hihopes | Digital Source | 17 | 9th November 2004 06:14 PM |
| Page generated in 0.06769 seconds (70.05% PHP - 29.95% MySQL) with 10 queries |
