CD Rom PSU output in Car - diyAudio
Go Back   Home > Forums > Design & Build > Parts
Parts Where to get, and how to make the best bits. PCB's, caps, transformers, etc.
Old 28th August 2004, 07:00 AM   #1
cwteoh is offline cwteoh  Malaysia
Default CD Rom PSU output in Car
I am fixing a CDROM in my car for CD player (Just for fun), CDROM needs +12V 1.5A and +5V 0.9A power. So I use 7812 and 7805 regulators with 2'' by 3'' inches heatsink in a small plastic case for each CDROM PSU output voltage.
At both 7805 and 7812 input pin I connected a ceramic 0.33uF Cap and Elna 2200uF ap at the both output pin. I am not sure it will work in my car or not. The heatsink not really hot for first 1 hour in air-con environment. Not sure what will happen when the CDROM is connected to my car amp (not live test yet).
Is anyone have this experience about this?
C.W. Teoh
Old 28th August 2004, 11:18 AM   #2
li_gangyi's Avatar
the 7812 might shut off...as it has only a 1A limit...maybe u could get a 3A part...
Kids in the back seat cause accidents...Accidents in the back seat cause kids...
Old 28th August 2004, 11:50 AM   #3
Family_Dog's Avatar
Send a message via ICQ to Family_Dog
I wouldn't bother using a 7812 at all - if you feel that your car voltage might be a tad high while it's being charged by te alternator, simply insert a 3A diode in series with the +12V DC supply.
As for the 7805, mount it on a decent heatsink (±100mm square aluminium with vertical fins) or better still, feed it's output into the base of a power transistor (still using a heatsink), such as a 2N3055 and take the output from there. Suggest you do a Google search for examples of such a regulator.
-Eric
Vintage Tube Hobby Group:
http://groups.yahoo.com/group/vintage_tube/
Old 28th August 2004, 12:32 PM   #4
li_gangyi's Avatar
he might be using a regulator to reject the noise that might appear from an alternator...not sure though
Old 28th August 2004, 12:44 PM   #5
Family_Dog's Avatar
Yes, or he could use a simple Pi-network (cap-choke-cap) to achieve the same affect. Better still to kill any Alternator noise at source by simply placing a cap (±0.5uF) across the alternator.
-Eric
Old 30th August 2004, 03:58 AM   #6
do you guys think this PSU will damage my car battery? what yours opinion?
C.W. Teoh
Old 30th August 2004, 04:10 AM   #7
just find out my 7812 spec. Model # is 78T12 CT regulator 12V 3A.
Should be OK for the CDROM?
C.W. Teoh
Old 30th August 2004, 08:44 PM   #8
Family_Dog's Avatar
Should be fine, but your voltage output might be a bit low however, because your input is not that high to start with. You should still use a heatsink for the device.
-Eric
Old 1st September 2004, 02:12 AM   #9
you are right... I am applying a 3x3 inches heatsink for each regulator. testing will be done by this week...
C.W. Teoh
Old 1st September 2004, 01:07 PM   #10
Immo_G is offline Immo_G  Australia
As long as you have a fuse I can't see a way to damage the car's power system. Not sure how gain would work out though, I've driven a car amp off PC, and its stupidly high ( had windows volume control on 1%, anything higher was too loud) .
Difference between SE output transformer and push-pull output transformers hilbert_mostert Tubes / Valves 12 8th March 2009 06:10 PM
3C24 in a SE output stage - output transformer impedance recommendation !!! aldovan Tubes / Valves 15 6th September 2008 11:18 AM
Adding secondary of output transformer into cathodes of output stage ? Eico ST-70 freddymac406 Tubes / Valves 3 21st April 2007 07:15 PM
Can An Output Transformer Change A Voltage Amp's Output Impedance From 0.1 To 47 Ohms kelticwizard Everything Else 11 25th March 2007 06:17 AM
I2S digital output in Marantz CD4000 and four TDA1541A with balance analog output iklari14 Digital Source 30 18th July 2003 01:57 PM
Copyright 1999-2017 diyAudio
