Parts Where to get, and how to make the best bits. PCB's, caps, transformers, etc.
CD Rom PSU output in Car
Old 3rd September 2004, 04:29 PM   #11
dmfraser is offline dmfraser  United States
Default Regulator Drop Out
Getting regulated 12V in a car is a problem as the linear regulators generally need 3V drop across them to work. If your regulator is not rated as a "Low Dropout" type, the voltage output will not be regulated and about 2-3V below the battery voltage. Regardless, you may get erratic voltage.
For the 5V supply, you may want to consider one of the "Simple Switcher" series from National, like the LM2596. They work very well and will dissipate almost no heat.
Dan Fraser
Old 4th September 2004, 02:01 AM   #12
cwteoh is offline cwteoh  Malaysia
that's is a good point... but do yo have any idea or different component to replace my current 7812? This is the problem I was think of yesterday.
C.W. Teoh
Old 4th September 2004, 03:02 AM   #13
li_gangyi is offline li_gangyi  Singapore
li_gangyi's Avatar
drop the regulator...and use a simple CLC filter instead...since u already have 12V from the car...otherwise a good solution will be to use LDO regulators ( which may not work when u're starting the car) or a small SMPSU from National's line up of simple switchers...
Kids in the back seat cause accidents...Accidents in the back seat cause kids...
CD Rom PSU output in CarHide this!Advertise here!
Difference between SE output transformer and push-pull output transformers hilbert_mostert Tubes / Valves 12 8th March 2009 05:10 PM
3C24 in a SE output stage - output transformer impedance recommendation !!! aldovan Tubes / Valves 15 6th September 2008 10:18 AM
Adding secondary of output transformer into cathodes of output stage ? Eico ST-70 freddymac406 Tubes / Valves 3 21st April 2007 06:15 PM
Can An Output Transformer Change A Voltage Amp's Output Impedance From 0.1 To 47 Ohms kelticwizard Everything Else 11 25th March 2007 05:17 AM
I2S digital output in Marantz CD4000 and four TDA1541A with balance analog output iklari14 Digital Source 30 18th July 2003 12:57 PM
