Parts Where to get, and how to make the best bits. PCB's, caps, transformers, etc.
noisy opamps
noisy opamps
Old 20th August 2004, 03:51 PM   #11
sam9 is offline sam9  United States
sam9's Avatar
you can get 3nV/sqrtHZ instead of 18nV/sqrtHZ if you use opa227 instead of TL072
Yup. The OPAx227 and OPAx228 families are a possability as well. From the application, I suspect that in most cases the opamp is being used at unity gain, which means the OPA227 is preferred, but if the gain is >5, the data shgeets say OPAx228 is prefferred. **Check the datasheets as I might have that bassakwards!!** While you are looking at the datasheets, note that these families have some limits on the input currents that can be used without damaging the device - you are probably safe - but check. The data sheets app notes also contain info on how to get the best results from these devices so read them a couple of times.
It's not my intent to send the guy off to buy new equipment, but I think that kind of application is potentially better achieved with digital rather than analog technology. If I were interesting in something like this I would be looking for a digital version working at 24/96 or better.
Old 20th August 2004, 06:31 PM   #12
djQUAN is offline djQUAN  Philippines
Send a message via MSN to djQUAN Send a message via Yahoo to djQUAN
well, if you have the extra money, you could just buy a gate. and set the threshold to cut off the noise when there is no music playing.
Old 20th August 2004, 06:59 PM   #13
tschrama is offline tschrama  Netherlands
I see in the TL072 datasheet that below 400Hz the input noise rises... to 20 even 40nV/sqrtHz .. the opa227 has a far more flat noise curve.... that's I still think you could consider using opa227 opamps to try to improve S/N.
g'luck,
Thijs
Old 20th August 2004, 07:05 PM   #14
p53 is offline p53  Germany
@ sam
The problem is, that there is nothing similar in the digital world! I know a lot of this hardware/software "Exciters" and "Spectralizers" but they do not the same thing. They all sound harsh. A Fletcher-Munson correction with digital equalizers (OK, Ive heared only the software solutions) also does sound "unnatural". And I can ensure you that Im not an analog freak.
Old 20th August 2004, 07:13 PM   #15
well the noise is not that bad. I think 78 db S/N is a realistic value. I just wanted to have 86 db
Old 21st August 2004, 06:02 AM   #16
dayvel is offline dayvel  United States
I'm pretty sure that the LM13700Ns *are* in the signal path being used as VCAs or VCFs. They are horrid little things. There is no drop-in upgrade.
noisy opampsHide this!Advertise here!
Help with noisy fan artcarmo Solid State 7 9th March 2009 07:34 AM
noisy noisy noisy noisy noisy tube dsavitsk Tubes / Valves 50 20th February 2006 05:07 PM
FS: Power Chip OpAmps and other OpAmps & D to A Converter dtm1962 Swap Meet 4 12th January 2006 11:07 PM
How can i use a noisy PSU ? Garbz Solid State 5 3rd January 2004 01:15 AM
ESP P3A amp, very noisy DaViruz Solid State 33 16th November 2002 07:07 PM
Copyright ©1999-2017 diyAudio
