Parts Where to get, and how to make the best bits. PCB's, caps, transformers, etc.
DIY benchtop power
DIY benchtop power
Old 16th August 2004, 08:51 PM   #11
alecwek is offline alecwek  Denmark
its because i will be testing things like mixing consoles where there will be loads of opamps...lights...etc....so the sum up i guess would be about 5 amps......
Old 17th August 2004, 03:53 PM   #12
Devil_H@ck is offline Devil_H@ck  Belgium
Devil_H@ck's Avatar
Send a message via ICQ to Devil_H@ck Send a message via AIM to Devil_H@ck Send a message via MSN to Devil_H@ck
You can use some LM317s in parallel, but instead of using a low value resistor on the output, use a diode. Then you know for sure they won't interfere with each other, but of course then you have to take in account the voltage drop over the diode.
But it's easy, you can stack like 100 of them in parallel and have a 150A power supply (don't forget to add a lot of heatsinks to that ).
Website: http://members.lycos.nl/anthonyvh
Old 18th August 2004, 11:33 AM   #13
thanks........
these things are cool....one of the shematics(i have attached with this post...) which is on the data sheets...shows what it calls a constant current\voltage source but there are two variable resistors...one for setting of voltage the other for current...can i just strap on a current and voltage meter and use this as a ...(reliable) benchtop power supply.....gotts find myself a few of these to try them out....what anout negative voltage suplies...can i just hook it up backwards and use it to sink voltage and current (instead of sourcing it) then that will be my dual supply???
thanks for the many posts....
DIY benchtop powerHide this!Advertise here!
Guidance for a benchtop power supply for car amp chemhaz Car Audio 3 14th June 2008 12:53 AM
HV benchtop power supply, help on opamp setup panos29 Tubes / Valves 17 20th April 2008 10:27 AM
Wiring car amp to a benchtop power supply bans27 Everything Else 5 15th March 2006 08:30 AM
Benchtop PS Bryan Tubes / Valves 30 25th January 2006 03:08 AM
Benchtop Power Supply from Elektor Electronics magazine AudioFreak Equipment & Tools 3 2nd May 2002 03:04 AM
