Go Back   Home > Forums > Design & Build > Parts
Parts Where to get, and how to make the best bits. PCB's, caps, transformers, etc.
Old 12th August 2004, 10:33 PM   #1
rkc7 is offline rkc7  United States
rkc7's Avatar
Default malfunctioning voltage regulator?
I recently assembled a power supply for my active crossover and I used a design from here:
http://ldsg.snippets.org/FILTERS/Pomann/kitsupply.htm
Anyway, the +15 lead reads just under 15V, but the -15 reads -19.5V. I checked over everything, and it seems correct, could this be due to a faulty voltage regulator? The regulators are 7815 and 7915. Thanks.
Old 12th August 2004, 10:44 PM   #2
johnnyx is offline johnnyx  United Kingdom
I would check for a short between the IN and OUT on the 7915. I've had that a few times. The pinout of the 7815 & 7915 are different; if you didn't use the PCB, check that from the data sheets. If there is a reverse - biased diode between IN & OUT , check it's the right way round.
Hope this helps.
Old 12th August 2004, 10:55 PM   #3
Electrons are yellow and more is better!
peranders's Avatar
If you are using 79xx, are you aware of that the negative regulator doesn't have the same pinout as the positive 78xx?
/Per-Anders (my first name) or P-A as my friends call me
Old 12th August 2004, 10:59 PM   #4
moamps is offline moamps  Croatia
Default Re: malfunctioning voltage regulator?
negative regulator doesn't work properly without any load. Put some resistor (ca 1k) to output and check once again.
Milan
Old 12th August 2004, 11:55 PM   #5
rkc7's Avatar
Thanks Moamps, I guess it was fine, just needed a load. It's measuring correctly now. And yes, I knew the pin configuration was different, and everything was correct on the board, that's why I was confused. Thanks to all.
RCA voltage regulator astouffer Tubes / Valves 10 7th September 2008 06:26 AM
voltage regulator Sebastiaan Power Supplies 2 12th June 2005 07:51 PM
Voltage Regulator zoro72 Everything Else 0 26th April 2004 05:30 PM
So your using a Voltage regulator Shoog Pass Labs 1 29th January 2003 08:04 PM
Voltage regulator help! kasra Solid State 7 23rd November 2002 02:07 PM
Page generated in 0.08007 seconds (75.53% PHP - 24.47% MySQL) with 10 queries
