Go Back   Home > Forums > Design & Build > Parts
Parts Where to get, and how to make the best bits. PCB's, caps, transformers, etc.
Old 9th August 2004, 07:53 AM   #1
Prune is offline Prune  Canada
Account Disabled
Question Quick relay/transistor question
Is it OK to have power at the emitter/collector of relay driving BJTs and motor driving MOSFETs if the bases and gates are connected to unpowered logic?
I ask because I keep my 5 V logic unpowered in standby (both Vdd and Vss at ground), except for the standby on/off controller and remote control reciever, but the unregulated 12 V going to the relays and volume motor is not turned off by a relay since I assumed current wouldn't flow through with a lack of signal at the base/gate. This way I don't have to worry about adding another relay to turn off the 12 V. Could something get fried or not work right in such a setup?
Old 9th August 2004, 08:04 AM   #2
Ouroboros's Avatar
Everything should be OK. I suggest you add a pull-down resistor (10k or so) between the gate and source of the switching FET to ensure that you don't get the possibility of a floating gate.
Although HCMOS outputs will go to a maximum of a diode drop above ground when no power is applied, other families like 74LCX have outputs that go high-impedance with no power applied.
Old 9th August 2004, 08:13 AM   #3
Account Disabled
The logic ICs whose outputs I'm using to drive the transistors are CD4023BCN, CD4027BCN, and CD4071BCN. The MOSFETs are driven by BJTs.
Old 9th August 2004, 01:52 PM   #4
jackinnj's Avatar
also -- resistors to the bases of the BJT's since CMOS isn't going to source much current --
Old 9th August 2004, 01:59 PM   #5
Ouroboros's Avatar
That's true. Do you really need to use CD4000 series at 5V? It's just that it really doesn't source much current at all at 5V. Can't you use standard 74HC parts?
Old 9th August 2004, 03:54 PM   #6
Account Disabled
Yes, I used near-maximum resistances that still toggle the relays.
Quick quick question ! guitvinny Pass Labs 6 7th February 2007 05:20 PM
muting transistor>relay,can i do this? Rodzilla Analogue Source 1 20th August 2004 01:22 PM
Quick Relay/Timer Help Needed woodrufj Parts 3 24th June 2004 07:05 PM
Transistor relay circuit more_power Solid State 12 21st May 2002 02:37 AM
Some quick transistor suggestions alvaius Solid State 2 26th April 2002 12:04 PM
Page generated in 0.10617 seconds (69.44% PHP - 30.56% MySQL) with 10 queries
