Go Back   Home > Forums > Design & Build > Parts
Parts Where to get, and how to make the best bits. PCB's, caps, transformers, etc.
Old 5th June 2002, 02:16 AM   #1
tiroth is offline tiroth  United States
Default Capacitor identification
Hi all. I'm hoping some of the forum gurus who can identify caps on sight (and faster than a speeding bullet no less) can help me out with some new finds from the bargain bins. Anyone know the composition and/or sonic attributes of any of these caps?
From left to right:
0.33uF/250V, ??
5uF/100V, 2%, West-Cap WF70U1505
5uF/50V, 10%, TRW X663F
0.1uF/50V, 20%, TRW 8336
Old 5th June 2002, 02:18 AM   #2
Deep orange are Sprauge in sizes from .0082-.22uF, 80-200V, 10%
Yellow wrapped is Sprauge .047uF/100V, 5%
Old 5th June 2002, 02:20 AM   #3
From left to right:
2uF/200V, Aerovox P8292ZN14
0.1uF/200V, 1%, BEC 9637
0.15/50V, 5%, G.E.
Micamold and El-Menco. Anyone have a site for identifying values?
I also have some yellow film caps similar to Sprauge by IMB, Wesco, Aerovox, CDE, and "Acushnet Acu-cap. Several white film caps by STK, "MP900".
Thanks very much to anyone who can offer some input.
Old 5th June 2002, 03:06 AM   #4
Banned
Default Surplus caps
Most of the caps you find surplus are Mylar also know as metalized polyester. TRW is now ASC.
http://www.faradnet.com/catalog/company/asc.htm
This might help to identify cap types also:
http://www.capacitors.com/pickcap/pickcap.htm
Alot of what a cap sounds like from construction rather than dielectric. IMB usally makes very good caps and the Sprauges and TRW are good caps also. You just have to listen to them. If you can find Electrocube brand caps they sound pretty good also.
European caps like Wima Rifa and ERO are also very good and are often marked for dielectric type:
MKT- metalized polyester
MKP- metalized polypropylene
MKC-metalized polycabonate
Old 5th June 2002, 11:11 PM   #5
dice45 is offline dice45  Germany
tiroth,
can help with the Mica colour code
(your 3rd pix, lower left corner. the brown square thing: El Menco, Cornell Dubilier, Sangamo, Aerovox or similar).
code has 6 dots, can be either RTMA or JAN or (ancient) RMA code.
Colours indicate same numbers , tolreances, multipliers as with resistor colour code of nowadays.
Capacitance is in picofarads (pF or µµF)
RTMA:
1st dot: white.
2nd dot: 1st digit
3rd dot: 2nd digit
4th dot: capacitor class (regarding Q, drift,insulation res. etc.)
5th dot: tolerance
6th dot: decimal multiplier
JAN:
same as RTMA, but 1st dot is black and JAN standard instead of RTMA standards apply
RMA:
1st dot: 1st digit
2nd dot: 2nd digit
3rd dot: 3rd digit
4th dot: voltage rating
5th dot: tolerance
There exist also similar looking micas with rectanguar shape and 3 dots. They have 20% tolerance, 500V rating,
1st dot: 1st digit
2nd dot: 2nd digit
3rd dot: decimal multiplier
In case a a 4th corner dot is left above the 1st dot, this dot indicates tolerance.
For further info please consult the Radiotron Desinger's Handbook, 4th ed., pp1340.
Those ancient micas can be crap and also be extremely good. Before you rely on the voltage rating, measure each and any sample. They may go boom and take your cherished output tubes with them to Nirvana. SS use is uncritical, Best use: shunting PS electrolytics and coupling caps. Also use them for FB and phono EQ. but by any means, compare them to good polystyrenes or polyprops.
General hint (exception: PS) use micas in homoeopathic doses; you would not like overdosing sonically
Greets,
Bernhard
Old 5th June 2002, 11:35 PM   #6
Banned
Angry Mica colour code
YIKES!!!! This is why I own two capacitance meters.....
"use micas in homoeopathic doses" I love it, what an interestingly poetic analogy. I say we vote Dice45 as the DIYaudio poet laureat.
H.H.
Old 6th June 2002, 01:27 PM   #7
Thanks for the help guys.
Old 6th June 2002, 03:56 PM   #8
A poet reading his poetry in public may have other nastys habits.
(Robert.A.Heinlein, Notebooks of Lazarus Long)
Greets,
Bernhard
Old 6th June 2002, 05:19 PM   #9
Banned
Default Lazurus Long
Hey! I read Time Enough For Love and Mr. Long has a LOT of nasty habits but at least building amps was not one of them. Your taste in sci-fi is very refined. Heinlien is the best, I just reread Strange in a Strange land.
H.H.
Old 7th June 2002, 12:45 AM   #10
Default Heinlein
Harry and all,
not only in sci-fi ... my taste is exquisite and expensive
concerning Heinlein, i am not that interrested in the sci-fi all too much albeit Heinlein's imagination is sometimes breathtaking. He manages however to depict utterly realistic fictionary societies of the future.
The moral philosophy underlying his stories is very much to my taste .... as the ethical values are .... and his definition of moral as group equivalent to survival instinct just hits.
Maureen Johnson from "to sail beyond the sunset" is an incredible and erotic female character ... love it. Most amazing: unconventional erotic athmosphere and moral philosophy do not disturb each other, quite opposite, very open-minded, just look at young Maureen's 10+6 commandmends.
I am not much of a democrat (German democracy turns out to be a gooey mess with a mighty minority dominating public opinion and even questioning election results, same with the US one ?), but the sort of democracy described in "Starship Troopers" really could work.
"stranger in a strange land" is a lil'bit overdone, not my taste.
Greets,
Bernhard
Capacitor Identification Help Please! jpjsenior Multi-Way 5 31st July 2009 04:29 PM
Capacitor identification–old PIO? m6tt Tubes / Valves 2 2nd April 2008 03:46 AM
capacitor identification, possibly old oil caps? m6tt Parts 0 2nd April 2008 02:22 AM
Capacitor Identification samkhanski Parts 3 21st December 2007 02:21 AM
Copyright ©1999-2013 diyAudio
