| Parts Where to get, and how to make the best bits. PCB's, caps, transformers, etc. |
Can anyone suggest a replacement, upgraded rectifier for the Quad 34 pre amp?
It's a L7918CV as standard (1.5 Amp, -18v)... I expect this can be improved, but can't find anything that appears any better from my usual electronic suppliers. Any suggestions would be appreciated. I have changed over all op-amps to burr brown, replaced all electrolytics with bipolar caps, and the pre is really singing - but just wanted to try and do some work on the psu side to finish the modifications off! Cheers. |
#2 |
Try 4 average shottkys, and change the big cap in the PSU for smth bigger and better, or all to smth bigger and better...
I have removed ALL caps between the different stages in the amp, too...and the input caps where I have DC under control. In its current form my LINNish friend prefers my 34 to my Croft Super Micro...my jury still out Don't know if changing the TL071 in the PSU for smth better helps... |
#3 |
Hi Zombie
That's good stuff, cheers. I'm no electronics expert, but I'm a total expert with a soldering iron which is why I'm so keen to have a go (have skills, lack knowledge). I already changed the TL071 in the PSU to a OPA134 (I think). Is it ok to uprate all of the caps in the PSU "compartment" in the 34, or could changing certain ones have an adverse effect? As for these shottky's - thanks for the suggestion, but not being a straight swap I'd need more info (sorry to appear kinda dumb here). I presume shottky's are kinda zenner diodes, and you're suggesting 4 in parallel? I'm willing to try anything, at almost any cost, it's sounding so much sweeter already, but you know how it is when you start doing something...! |
#4 |
Hello!
I am about the same, but have knowledge about the componanets etc, but lack deeper knowledge - that's why I pester this kind community I misunderstood you, thought you were talking about the rectifier bridge - D34. If you are not familiar with these things, forget about the shottkys. Maybe you can change the 7918 for smth better, but check pin compability. A guy here at the forum says the PSU is very good without any modifications, that he can't see any noise on his scope... I changed the C14 (1000uF) for an Elna 2200uF, the 22uF and 100uFs for Elnas - mind that the 100uF are not inside the "box", but at the 4066 switches. Have you bypassed the +/- supply pins of the opamps with small 0,1uF film caps to ground? Quite necessary if you use faster opamps. The 100uF caps I bypassed with a wire where the following (but check DC at them first): C89/90, C91/92, C30/31, C34/48, C72/78 Other caps I shorted: C85/86, C36/37. I also shorted out the buffer opamps IC24/27 and replaced all the others with OPA627. The 4066 chips are replaced with MAX4066A, also thinking about bypassing their supply with small film caps, but I am not sure if it will impove anything. Cheers Tom |
#5 | |
You may wish to rephrase your query as the L7918 sounds more like a regulator than rectifier. |
#6 |
It is a reg, I misunderstood...
#7 |
It is probably not a good idea to bypass C30/31 and 34/48 as these provide DC blocking to the volume and balance pots and there removal will cause the pots to become noisy. I usually replace these with bipolar electrolytics
Stuart |
#8 |
405man: thanks, do you mean audible scratching noise when turning the pots? Would bypassing the 100uFs with film caps be an improvement?
Would changing the pF and small nF caps to silver micas or teflons give any audible improvement? |
#9 |
Ok I'll embark on changing out the psu caps shortly. As for the faster opamps - no I haven't installed any additional caps... Is this really necessary?
#10 |
Question for 405man.
Have you found a preferred bipolar ? The blackgate ones are vastly expensive, I have seen some smaller cheaper ones in yellow fron Nikai - are these what you use. I'm thinking along the same lines for the AC coupling caps in my Quad 44. There are a pair of 100uF electrolytics in the signal path just before the output RCA's |
| Can this be Upgraded? | normalicy | Car Audio | 13 | 24th January 2008 05:17 PM |
| $30 amp upgraded | amt | Class D | 323 | 21st April 2006 07:48 PM |
| Anybody heard about Tarzian Silicon Rectifier for Tube Rectifier Replacement? | zxx123 | Tubes / Valves | 4 | 21st February 2005 04:02 AM |
| Bridge Rectifier Replacements and Single-to-Quad Adapters?? | Sampsa | Parts | 0 | 15th June 2004 03:09 AM |
| Page generated in 0.11219 seconds (82.13% PHP - 17.87% MySQL) with 11 queries |
