| Parts Where to get, and how to make the best bits. PCB's, caps, transformers, etc. |
Just wanted some input from the forum on this...
1) What type of shielded wire is the best to use? Is 22awg coax a good choice? Is so, where is a good place to purchase some? 2) When connecting the shield to ground, should it be connected to chassis ground? Or can it be run to a ground connection anywhere (i.e. on a board)? Thanks in advance!
gravity always wins |
#2 |
The usual place where shielded wires is used ( in audio) is for carrying low level signals like the input signals. The most obvious one is from the input socket to the preamp board .
Shielded wire comes in several grades. If you have no idea what to buy and find it hard to locate a supplier, you should just buy twin core shielded wire for microphone use . Use one core as the ground lead and one as the 'hot' lead. At the input end connect the ground lead to the earth on the input socket. At the amplifier end connect the ground lead and the shield to the board's input ground terminal. The outer shield is not connected at the socket end. Two companies that makes very good cable for professional audio use are Belden and Canare. Your supplier would be able to suggest which type to use. Check out the following for technical info on cables. http://bwcecom.belden.com/college/Techpprs/wcfsbetp.HTM http://www.canare.com/otherpdfs/VS88551.pdf Cheers.
AM |
#3 |
Thanks much! That was exactly what I was looking for
#4 |
If it's not to late, missed this one...
I stock lot's of shielded wire: Canare GS 6 sort of like Guitar cord size or RG 58/59 Coax at .25ft have it in Red and Blue color. Teflon shielded in 20 Awg and 22 Awg 1 cond .25ft .20ft RG Coax in PVC and Teflon multi-conductor PVC/Teflon shielded too... Steve @ Apex Jr. www.apexjr.com |
#5 |
Depending on what you are doing. Belden and Canare have good choices for reasonably priced.
For internal wirings I like Belden RG-147. You can find it at mouser.com or smallbearelec.com. It is a mini-Coax and for short connections it is great. For like guitar/instrument or general cable applications, Canare GS-6 or GS-4 work great. Belden, Mogami are also great inexpensive choices. You should probably hook it up to the signal ground. So if the signal ground is the chassis, then do the chassis. If it is on the board, use the board. Often the chassis ground and board ground is the same with the signal ground. |
| Filament Wiring - Shielded vs. Twisted? | k9swc | Tubes / Valves | 21 | 27th May 2009 07:12 PM |
| Shielded vs twisted pair in internal wiring | zigzagflux | Tubes / Valves | 4 | 19th June 2007 10:59 PM |
| RG59 Coaxial shielded cable for input wiring? | John Biles | Solid State | 77 | 8th December 2005 09:29 PM |
| I'm wiring my 4 channel 8 parallel LM4780 boards... check my wiring :) | Audiophilenoob | Chip Amps | 9 | 16th August 2005 04:37 AM |
| shielded vs. non-shielded | mytool4u | Instruments and Amps | 12 | 7th July 2005 10:12 PM |
| Page generated in 0.08053 seconds (73.66% PHP - 26.34% MySQL) with 10 queries |
