Parts Where to get, and how to make the best bits. PCB's, caps, transformers, etc.
power ratings of resistors
Old 4th August 2004, 05:24 PM   #11
dhaen is offline dhaen  Europe
diyAudio Moderator Emeritus
dhaen's Avatar
Wink Nice schematic
Caps go bang when the leakage current through them is too high. That will happen if the polarity is reversed, or if their voltage rating is exceeded.
Don't forget that the DC across those caps will be nearly 1.5 x the AC into the rectifier. Also the AC voltage may be 20% higher than specified with no load current being taken.
I'll pray for your caps...
Old 4th August 2004, 05:53 PM   #12
6SN7GT is offline 6SN7GT  United Kingdom
6SN7GT's Avatar
dhaen,
You beat me to it .. I couldn't get at diyAudio .. it just timed out
The caps almost certainly were connected reverse polarity.
The sequence of events, time line, and the consequence says this is most likely.
I can hear the bubbles forming
That is one of the best circuit diagrams ever, alecwek !
Assuming it's to scale, I calculate the BANG to be 108.43dB spl at 1 metre
Old 4th August 2004, 06:10 PM   #13
Netlist is offline Netlist  Belgium
Netlist's Avatar
Ohm's law?
Love the drawing, be careful though!
/Hugo
Old 4th August 2004, 06:27 PM   #14
jackinnj is offline jackinnj  United States
jackinnj's Avatar
A 50Kohm/20 Watt Vitreous Dale resistor is about 1.5 inches long, .6 inches in diameter, the sand cast power resistors are a little smaller.
Bleeders -- you should figure that the value of the bleeder resistor will reduce the voltage on the capacitors by about 90% in the time it takes you to remove the amplifier cover -- 30 seconds -- the equation is: V(f) = V(i) * e^(-t/RC).
where Vi is the initial voltage and Vf the final voltage --
let's say you are using 470uF of filtration on 400 VDC -- a 27K ohm resistor will bleed the caps by 90% in 30 seconds or thereabouts.
the current drawn by the bleeder is 400V / 27000 Ohms = 14.8 ma. The power is thus (.0148^2) * 27000 = 6 watts. A 10 Watt resistor will accomodate a big swing in the supply voltage. this is a lot of power to burn, however.
Old 4th August 2004, 08:14 PM   #15
alecwek is offline alecwek  Denmark
ok... now that u mention it...the caps were connected in revers.....man!!!its cause when i kept flipping the breadboard round ...up down....alittle to the left!!!...i guess i must have gotten the rails the wrong way round........i drew schematics on the non copper side before soldering so i had to keep flipping to solder.....man i gotta learn how to make pcb.....also u should see how crap my finished peices look...hmm...ah well.....
what is the best looking.....quickest.....(cheapest )way of making curcuits....pcb look a bit expensive and complicated....plus how on earth do you sheild pcb lines..........
Old 4th August 2004, 08:16 PM   #16
oh and thanks for all the help so far
Old 4th August 2004, 08:38 PM   #17
6SN7GT's Avatar
Ah ha!, I think we got to the bottom of the exploding caps problem OK.
So that's good.
I agree, you have to be careful with breadboard designs and remember which side you are working from.
Why do you want to shield PCB lines ?
Because the interconnect wiring is effectively 2D, crosstalk (interference) can be managed reasonably well.
You have something in mind I guess ? Do tell.
Old 4th August 2004, 09:54 PM   #18
well its just cause i heard,....from one of the thousands sources (that are found in great abundance in electronics)
that high voltage lines should be sheilded ...and also high voltage points...caps..etc...i guess cause of noise, also i could imagine it being ......ummm.....healthier, to keep power rails and high voltage ,current lines sheilded...less chances of accident...but man, electronics is polluted with so much good advice its hard to get a grip on it all....
power ratings of resistorsHide this!Advertise here!
Hammond PT power ratings dsavitsk Tubes / Valves 4 23rd August 2009 08:23 PM
Power supply resistors power ratings Nihilist Tubes / Valves 13 31st July 2009 01:47 AM
Tube power ratings Brian Donaldson Tubes / Valves 19 20th November 2005 02:59 PM
Power Ratings BAM Multi-Way 1 13th October 2001 11:05 PM
