Go Back   Home > Forums > Design & Build > Parts
Parts Where to get, and how to make the best bits. PCB's, caps, transformers, etc.
Old 3rd August 2004, 10:07 AM   #1
alecwek is offline alecwek  Denmark
Unhappy Oh Mannnnn??!!!
i just finished soldering together my amp......then it hit me ...(right when i was gonna solder it into the case and solder the transformer in)....it hit really hard...the problem is i cant tell what to connect to what on my wave bridge recifier...see my transformer has about ten pins....i have connected the two input pins in fine....and all the others pins read 40 volts ac....i know that if it was an ordinary two in pins two output pins transformer then the two output pins would be the same ac voltage just that they would be 180 degrees out of phase ie when one is in the positve swing the other will be negative....so how do i found out which two pins to connect to my rectifier....how do i find out which pins are out of phase with each other...or doesnt it matter....or should i just connect any which pins to the wave bridge rectifier kiss my parts goodbye and hope for the best.....
Old 3rd August 2004, 10:09 AM   #2
oh and before u suggest it...i dont have a scope yet...im saving up for a 100mhz scope....its gonna have to wait atleast till next pay cheque
Old 3rd August 2004, 10:16 AM   #3
Netlist is offline Netlist  Belgium
Netlist's Avatar
Do you have some more info on the trafo? Whats written on it?
Picture perhaps? With the wires well in view?
/Hugo
Old 3rd August 2004, 10:19 AM   #4
sorry dont have a camera......but it says
tam b 0205
3-3666-020-00-13
treid searching for data sheet but no luck i think its made buy some obscure elcheapo compony thats why....got it off an old stereo.....
Old 3rd August 2004, 10:29 AM   #5
Jennice is offline Jennice  Denmark
First thing to do is to make sure if your windings (which measured 40V ac per set) do not have electrical connection from one set to the other. If they have, it's a transformer with center-tap. This will make things a little different.
If your windings are isolated from each other, then the phase doesn't matter as long as you use full bridge rectifiers (with 4 doides) for each secondary.
Jennice
I get paid to break stuff. My g/f gets paid to play with children. Life is good.
Old 3rd August 2004, 11:15 AM   #6
im not dumn im just a little slow...ofcoarse check which two are pairs by seeing which are electriclyy in contact!!!!!!!!!!!!!!
why the &€"§)= ?!!!!! didnt i think of that...
thanks A LOT!!!!
yeah i figured it out know...TAK
Old 3rd August 2004, 11:25 AM   #7
You're welcome... (Det var så lidt)
Say... what are you working at, and whereabout are you located?
Roskilde, for my part...
Jennice
Old 3rd August 2004, 12:01 PM   #8
københavn...making a small shitty amp.....cause im off to university and i cant carry my old stereo....so i cannibalised it left out all the unneccesary stuff...the digital eq cd tape......putting it in a smaller box witrh just the amp and some volume controls....later i will think about building a better quality amp.....once im settled in at uni...
Old 3rd August 2004, 12:29 PM   #9
Jay is offline Jay  Indonesia
You know what? While I can say that I was far above average, I finished my university degree in 9 years! And I don't have good career either. You sure know where I was when everybody else was attending the class. Be carefull of your hobby Oh, and watch out your bank deposit!
Old 3rd August 2004, 12:44 PM   #10
Thanks for the warning, Jay!
Personally, I don't know if you'd call my choice a career move, but I work as an QA engineer, and I like it. This is what's most important to me. I also took a little longer (4 years in stead of 3.5, though). During my studies, I slao spent time with making DIY stuff in the spare time. Fortunately, one of the teachers was a SERIOUS diy'er, which was a great resource for the students.
Might I suggest a GainClone as your next project? I haven't tried it myself, but everyone seems to like it, and it's a rairly simple project in all regards. Not the most powerful thing on earth, but well sounding, they say.
Alecwec, are you going to attend DTU, Lyngby? What line?
Page generated in 0.10880 seconds (80.43% PHP - 19.57% MySQL) with 9 queries
