| Parts Where to get, and how to make the best bits. PCB's, caps, transformers, etc. |
This is a fool question, but this type of caps are good for audio?
#2 |
Ola, tudo bem?
This is long to read, but it's worth it if you're interested in audio diy! http://www.capacitors.com/picking_ca...rs/pickcap.htm And yes, if you need a higher value cap, so you got to choose an aluminium electrolytic (the mostly upright standing cans) you should better choose a low esr type. Cheers! Dominique |
#3 |
Thanks Dominique!
By the way, Berlin in France ?? Cumprimentos, Pedro Martins |
#4 |
Jung's article is definitely a "must read". So is Bateman's
series from Electronics World over the past couple years. If EW is unavailable to you, you can order the whole series plus other goodies from him for 15 pounds sterling (plus probably a little more for postage outside of GB) Cyril Bateman 'Nimrod' New Road ACLE Norfolk NR13 3BD England
bel |
#5 | |
I just chose the french flag because it's my nationality. Today I too searched for low esr caps, but they're not all that easy to get everywhere, and sometimes a bit expensive, so in the cases when you can go along with less capacitance a Wima Mks2 6.8uF/50V or 10uF/16V that might be the better alternative to a low esr electrolytic. Cumprimentos too (thanks for the formula, I only remembered "beijos" which isn't always adequate) Dominique PS. nao me lembro bem do portugues, so falo um pouquinho |
#6 |
thanks, Brian!
That sounds very interesting! I just wish I didn't have much more things to read here already than I got time on my hands Cheers Dominique |
| bypass caps for bypassing mylar caps? | crippledchicken | Multi-Way | 4 | 27th February 2008 04:24 AM |
| Replacing multi-section caps with multiple caps? | Sir Trefor | Tubes / Valves | 1 | 29th May 2007 10:17 PM |
| Silver Mica caps VS Polystyrene caps | KevinLee | Parts | 24 | 17th September 2003 03:01 PM |
| Replacing ceramic disc caps with silver mica caps? | G | Solid State | 5 | 18th November 2002 01:02 PM |
| FILM Caps to assist Big ELYT Caps | gromanswe | Parts | 0 | 9th July 2002 08:16 AM |
| Page generated in 0.09839 seconds (78.69% PHP - 21.31% MySQL) with 10 queries |
