Parts Where to get, and how to make the best bits. PCB's, caps, transformers, etc.
Balanced cable and RCA connector: how to wire them?
Old 30th July 2004, 07:41 PM   #1
Bricolo is offline Bricolo  France
Bricolo's Avatar
Default Balanced cable and RCA connector: how to wire them?
Hi all,
I've foune a nice audio cable, but it's intended for balanced connections (2 wires and a shield). All my audio rig uses RCA connections.
What would be the proper way to connect the cable to the RCA?
-both wires at the signal, and the shield as ground
-one wire as signal, the shield and the other wire to the ground?
Alex
Just remember: in theory there's no difference between theory and practice. But in practice it usually is quite a bit difference... Bob Pease
Old 30th July 2004, 08:53 PM   #2
electroaudio is offline electroaudio  Sweden
The best way to connect it is by connecting the sheild to ground on only one side (The recieving end is theoretically the best) and then connect the signal and ground thru the inner two cables.
Old 31st July 2004, 06:18 AM   #3
Bricolo's Avatar
That's also a question I wanted to ask: this technique has also been adviced in some application note (don't remember wich one).
But, can't this long (1 or 2m) shield connected at only one end act like an antenna?
Old 31st July 2004, 06:28 AM   #4
Thunau is offline Thunau  United States
Thunau's Avatar
See Rane reference at the link
http://rane.com/note110.html
"Most people just say what they know, the wise ones know just what to say."
Old 31st July 2004, 01:03 PM   #5
pooge is offline pooge  United States
Grounding the receiving end is not "theoretically the best". There are advantages and disadvantages to each way. Experts in the field usually recommend grounding the shield at the source end.
In any event, you should mark the cable to know which end has the shield grounded. See the attached link for the reasons for grounding the source end.
Whitlock paper on grounding
Old 31st July 2004, 01:04 PM   #6
They say so. thats why it should be connected at the recieving end and not at the senders end.
But you can probably shortcurcuit the "antenna" with a small capacitor at the senders end.
more about grounding and antennas here..
http://www.prosoundweb.com/studyhall...ing/ground.php
Old 31st July 2004, 01:16 PM   #7
Read his signature, thats why i choosed that phrase.
Old 31st July 2004, 03:10 PM   #8
Yes. You can use a capacitor at the receiving end to eliminate the possible disadvantage of the antenna problem, while maintaining the advantage of having the shield connected to ground at the source end, which connecting at the receiving end only doesn't provide.
Old 13th April 2014, 07:04 AM   #9
Moondog55 is offline Moondog55  Australia
Moondog55's Avatar
Which is the best end to "Couple" at? I thought that joining at the RCA end was preferred ?
QUOTE" The more I know, the more I know, I know (insert maniacal laugh >here<) NOTHING"
Old 13th April 2014, 08:13 AM   #10
tinitus is offline tinitus  Europe
diyAudio Moderator R.I.P.
I think he has RCA both ends
with balanced cable, and shield connected only at one end, this is commonly called pseudo-balanced
which end to connect shield, sender or receiver, might depend how electronics are wired internally
and whatever sounds best
but I have usually preferred to connect all shielded ends to preamp, maybe acting a bit like 'star ground shield'
sometimes we know very little, and sometimes we know too much
Balanced cable and RCA connector: how to wire them?Hide this!Advertise here!
will 30awg wrap wire terminate into rj-45 connector? riotubes Parts 0 28th September 2007 11:05 PM
How do I wire a balanced to 5-way binding post? guitaro Multi-Way 3 5th April 2006 01:34 AM
Finished my DIY Copper foil speaker cable, what connector to use? Guijs Everything Else 4 19th October 2005 11:31 PM
How to wire a Ixos Gamma 7 bi-wire cable mangalchacha Multi-Way 1 13th April 2005 03:58 PM
PS cable and connector rif Parts 3 1st February 2003 05:35 PM
