| Parts Where to get, and how to make the best bits. PCB's, caps, transformers, etc. |
Is it ok to use 5% 0.1 ohm output resistors?
#2 |
It depends.
Jesus loves you. |
#3 |
Depends on what?
I will be making an amp by bootstrapping an LM3886, and adding an output stage. I'm not yet sure how many transistors I will use in parallel, but it probably will no less than 4 per rail. How does the accuracy thing work? If a resistor is 0.1 ohm 5%, then do I multiply 0.1 times 5% to get how much the value will vary? So this resistor's value would be between 0.095 and 0.105 ohms? Or is it 5% of something else? |
#4 | |
#5 |
Depends on the application of course.
If the voltage difference is not ok when you calculate with maximum and minimum possible values in the +/- 5% range, get a whole bunch and do some comparing and matching. If you have cheap/free output transistors, try it and see if anything blows up. Use a cover though!
Jesus loves you. |
| Opamp output resistor.. | jethdub | Chip Amps | 3 | 21st January 2008 03:46 PM |
| preamp output stage resistor from output to V- ? ? | Bernhard | Solid State | 4 | 19th October 2007 02:55 PM |
| why a cap and resistor at output of leach? | Wagener | Solid State | 2 | 13th August 2004 07:08 PM |
| Gainclone output resistor | aeronaut | Chip Amps | 17 | 7th May 2004 09:26 PM |
| GC 0,22R output resistor | 2Bak | Chip Amps | 15 | 3rd March 2004 07:19 AM |
| Page generated in 0.07781 seconds (71.67% PHP - 28.33% MySQL) with 10 queries |
