| Parts Where to get, and how to make the best bits. PCB's, caps, transformers, etc. |
Does anyone recognze this 8dil IC?
I want to replace it with some other more modern bargraphdriver but i dont know how the 267works. Anyone have any old datasheets or an old catalogue where the pins are marked? Please... |
#2 |
Use LM3915...
This is in no way a replacement part, but you can assemble a ckt from this and make the LEDs work. This will need little struggling, and wiring Best of Luck. _____________________________ Gajanan |
#3 |
#4 |
The TFK U267 was made in the eighties and the IC Master lists it in the group 'Bargraph LED' and you say there are 8 pins. You can easily trace the pins.
Desoder and remove the ic and find its supply pins. That eliminates two pins. If the IC drives 5 LEDs, then finding the input pin should not be a problem. _______----------______------__--------__--__--_-_--__-- Gajanan |
#5 |
The part is available at
www.mushroom.co.uk/uu.htm ______----___---__--_--_-_------____________ gajanan |
| Page generated in 0.07897 seconds (69.65% PHP - 30.35% MySQL) with 9 queries |
