| Parts Where to get, and how to make the best bits. PCB's, caps, transformers, etc. |
What measurements with DMM do you make to check whether a diode or a capacitor is undamaged or not ? Thanks in advance. MB |
#2 |
For a capacitor, discharge it by putting a load across or just by shorting the leads (may be dangerous).
Then connect the meter, resistance will continue to increase until it is read as Infinite. You should also condition the capacitor if it is old. Do a search for capacitor conditioning. For a diode, some meters have a diode tester function. Or you can hook up a battery and an LED with the diode in series in the correct way. Then flip the diode, and the LED should go off. |
| Capacitor & diode replacements | dognut | Parts | 2 | 20th February 2009 11:59 AM |
| diode bridge - 10000uF cap - diode tube - small cap - HV+ | engels | Tubes / Valves | 5 | 29th January 2008 10:16 PM |
| hybrid power supply: diode bridge into diode tube | engels | Tubes / Valves | 8 | 24th September 2007 09:18 AM |
| d10 diode | WordUpOnLCDs | Parts | 9 | 14th March 2006 09:32 AM |
| Teac VRDS-7 Laser Diode Check | coliny | Digital Source | 2 | 4th February 2004 09:49 AM |
| Page generated in 0.05626 seconds (67.47% PHP - 32.53% MySQL) with 10 queries |
