NOS capacitor testing ? - diyAudio
Go Back   Home > Forums > Design & Build > Parts
Parts Where to get, and how to make the best bits. PCB's, caps, transformers, etc.
Old 25th July 2004, 03:17 PM   #1
Default NOS capacitor testing ?
I have a few NOS Marcon 15,000 uf 63v caps. Probably
20+ years old. The few times lately I have used any of them I haven`t had any problems but is there any way to tell if they
are drying out or how much useful life they have left.
Thanks,
Woody
Old 26th July 2004, 03:59 AM   #2
ashok's Avatar
Default Where are the capacitor guru's ?
No one seems to have replied to this.
If your capacitor measures out OK for capacitance , I think the electrolyte probably is intact. Remember that most electrolytic caps are +/- 20 % of the label value.
If your leakage resistance is low it probably has passed its mid life !
That will cause it to heat up and slowly die. Check the ripple on it while working and see if it is in the normal range. If it is, I guess it will last long enough.
Then again I am not a capacitor guru . You should google for 'reconditioning old electrolytic capacitors' . There were some nice writeup's that I saw a while ago.
Cheers.
AM
Old 26th July 2004, 04:46 AM   #3
You need to reform them since they've been in storage for so long. Probably best to create a power supply circuit that's adjustable to 60V. Then go 10v at a time til you get to 60V. You'll aso need a load past the cap which will also act as a bleeder to drain the voltage after you turn it off. Probably about 20 hours at each stage. Don't proceed if the cap gets hot - this means there's internal resistance - let it stay at one voltage til it's not hot.
Testing MTX amp baja200merk Car Audio 1 18th September 2007 01:43 AM
Testing for new DAC. tube-lover Digital Source 1 18th March 2007 02:45 PM
Copyright 1999-2017 diyAudio
