| Parts Where to get, and how to make the best bits. PCB's, caps, transformers, etc. |
#11 |
I think the advice from sek regarding thoroughly checking for shorts and dry joints should be you first step. Use an illuminated magnifier and remake any joint that looks less than perfect and run a blade between adjacent solder pads even if no short is visible. Always check the basics and assume nothing.
Apart from that have you got any pics of the internals of the player, it probably won't help but I'd be interested to see what's inside. |
#12 |
FYI: The 2134 is a superb op-amp...I see no reason to go with a 637.
Try reversing you actions (re-install original parts) and see if it still works. -Matt |
| What has happened??? | shepperd | Everything Else | 0 | 17th November 2006 10:11 AM |
| What happened to... | mikeks | The Lounge | 4 | 21st May 2005 12:08 PM |
| what the h*ll happened? | hifi | Everything Else | 10 | 4th March 2004 08:45 AM |
| Whatever happened to N.E.W.? | Michael Rothacher | Solid State | 0 | 25th August 2001 10:11 PM |
| Page generated in 0.06988 seconds (69.12% PHP - 30.88% MySQL) with 10 queries |
