Go Back   Home > Forums > Design & Build > Parts
Parts Where to get, and how to make the best bits. PCB's, caps, transformers, etc.
Old 22nd July 2004, 02:30 PM   #1
Default high voltage regulator problems
I have a sulzer like voltage regulator. Since I am using it in high voltages, I need to elevate opamp supply rails and the ground potential of active voltage reference. I am sampling the voltage at output directly after series-pass device. I have a voltage divider connected from output to ground. I have connected the middle point of voltage divider (that is 5 volts below the output) to the opamp negative supply rail and also to the ground of active reference device. Opamp positive supply rail and the active reference supply is elevated about 10V on top of the negative supply rail. Is there any side-effects of such a connection ?
Having measured the circuit output, it is continously changing between [Vexpected-3, Vexpected+3]. Is it normal ? If not, what could be the reason ?
Is there any way to measure the output resistance of this circuit for different frequencies by a DMM ?
Is there any reason to support more current than total quiscent current required ?
Thanks in advance.
MB
Old 22nd July 2004, 03:55 PM   #2
jackinnj's Avatar
Default Re: high voltage regulator problems
Thanks in advance.
MB
may help to describe the voltage you are trying to derive from the rails and the permissible excursion.
Old 22nd July 2004, 08:51 PM   #3
Output is 380V.
Negative rail is 375V, positive rail is 385V.
Old 22nd July 2004, 08:59 PM   #4
Circuit is like....
Old 22nd July 2004, 11:11 PM   #5
jackinnj's Avatar
i have used the following as a HV regulator -- its from Horowitz and Hill "The Art of Electronics" -- I use a DAC to derive the voltage reference -- shown here is a fixed reference. you will have to choose your own compensation RC values for best results, as well the voltage divider for the error amplifier.
Old 23rd July 2004, 10:06 AM   #6
Hi jackinnj,
How do you get supply rails of error amplifier (opamp) and fixed reference here ?
MB
Old 23rd July 2004, 12:00 PM   #7
jackinnj's Avatar
In the design in which I modified an Heath HV Power (Microprocessor Controlled Adjustable Power Supply) supply there was a spare center-tapped filament winding. In another supply I used a wall wart, doubled, rectified, filtered and regulated -- in the full wave doubler you pull the ground from the junction of the two capacitors. if you are careful in the layout it will work just fine. You can do the same thing with a non-center tapped filament winding.
High Voltage Regulator mod_evil Power Supplies 36 28th October 2011 12:48 PM
High voltage, high current super regulator, possible group buy peranders Group Buys 54 2nd June 2009 09:43 AM
High Voltage regulator PS maxpou Power Supplies 1 29th April 2006 07:14 PM
High voltage regulator sparkle Tubes / Valves 45 29th August 2004 05:52 AM
Page generated in 0.10292 seconds (79.30% PHP - 20.70% MySQL) with 11 queries
