| Parts Where to get, and how to make the best bits. PCB's, caps, transformers, etc. |
To date, I've just built a few simple mic preamps, all portable, so battery powered... But in my next project (phono preamp) I'd like to build the power supply too. I read a few things on power supplies, but finally I lost patience and would like to start rather yesterday than tomorrow My op-amp circuit wants a dual powersupply, and I wonder which way to go: (I don't mention rectifier nor caps as this isn't concerning the problem...) Should I use a simple transformer and an IC which does the rest for me: splitting and regulating the (DC) voltage at the same time (e.g the LM325 or the RC4195). That would result in fewer parts. Or am I better off using a transformer which gives me 2 voltages which I feed into two separate regulators? More parts, but possibly some advantages...? (e.g the one on rjm's site: http://www.geocities.com/rjm003.geo/.../diy_pho5.html - you have to scroll down for a bit) Cheers! Dominique PS. oops, just saw the LM325 is obsolete (It figured in Horowitz /Hill) |
#2 |
#3 |
And make sure you studied the datasheets of the standard regulator ICs that come into play here: LM317, LM337, LM1086, etc...
I'd go for the dual version, as you don't have to save each millivolt or -watt in a line power supply, while saving money and time is worth the couple of extra parts and board space. You'll find plenty about such power supplies on diyaudio, just do a ('nother) search. Care for low noise, efficiency and maximum power are unimportant for your application. Most people (and manufacturers) just implement the manufacturer's standard schematics to get started, then do some custom modifications. You can - of course - do some more research and read about the Jung "super" regulator. Cheers, Sebastian. |
| LM4562 (dual op-amp) simple preamplifier | veteran | Chip Amps | 45 | 5th October 2007 03:33 PM |
| Building a dual rail battery power supply? | pjpoes | Parts | 4 | 22nd January 2007 08:10 PM |
| Building a Preamp:Dual Outputs Question | mourip | Tubes / Valves | 3 | 21st May 2006 07:19 PM |
| Help building a powersupply for car audio in home use. | mattjk | Power Supplies | 1 | 18th November 2004 10:52 PM |
| Simple Dual Car Battery Charger | Matttcattt | Car Audio | 12 | 25th January 2004 07:28 PM |
| Page generated in 0.07845 seconds (72.88% PHP - 27.12% MySQL) with 10 queries |
