| Parts Where to get, and how to make the best bits. PCB's, caps, transformers, etc. |
I make guitar pedals, and need to find an alternate source for 16mm alpha pots with round shafts (not knurled or D type) and must be solderlug type, not PCB
here's a pic of what they look like Unfortunately all i can find is linear. I do have a regular source for them, but they are closed until the end of the month, and are also out of them... so im looking at about sepember before i see them. I could use another brand, but mounting would have to be the same, and i need to be able to buy them for under $1 in quantities of either 10 or 50. Please help. thanks |
#2 |
Use linear pots and put a reisitor of about 50K between the wiper and ground. Experiment a bit until you find the taper you want. This assumes the pot is being used as a 3 terminal variable voltage divider and that your drive circuit can handle a varying load impedance.
Dan Fraser |
#3 |
See my Electronics webpage -- the home of Vacuum Tube Drag Racing. The key to being a successful Audiophile: "I reject your reality and substitute my own!" |
| 100k linear pots, any idea? | edrel sison | Tubes / Valves | 4 | 8th March 2008 01:52 AM |
| EL-34 and 100k pot | podboy | Tubes / Valves | 1 | 26th June 2007 11:49 PM |
| WTB dual gang 16 mm 100K PC mount pots | chipco3434 | Swap Meet | 0 | 9th December 2006 01:44 AM |
| Alps pots vs. TKD pots? TKD worth the extra$$? | G | Tubes / Valves | 11 | 17th August 2004 04:33 AM |
| 100K linear cermet pots | HarryHaller | Swap Meet | 0 | 19th September 2002 07:18 PM |
| Page generated in 0.06573 seconds (69.71% PHP - 30.29% MySQL) with 10 queries |
