Go Back   Home > Forums > Design & Build > Parts
Parts Where to get, and how to make the best bits. PCB's, caps, transformers, etc.
Old 20th July 2004, 03:02 PM   #1
KT is offline KT  United States
Default Repairing Scraped Winding on Toroid
Hello,
I bought a used toroidal power transformer and received it today. It was in good shape but for one thing.
When the guy packed it, he put the mounting plate on the top without the rubber pad. The edge of the plate up scraping a bit of the insulating tape and, perhaps, a bit of insulation off of one of the windings.
The damage is small, maybe 1/2cm on top of the winding. The wire is secure so probably won't slide around and none of the other windings are exposed.
My question is, how does one repair this? Is there some sort of self-adhesive clear tape (like the tough tape that protects the toriod) that I could stick on, or should I use something like a bit of epoxy?
I could use regular black electrical tape, but the adhesive on that doesn't seem to durable and there must be a more elegant solution.
TIA,
KT
Old 20th July 2004, 03:18 PM   #2
Frazzled's Avatar
Clear nail polish or if you fancy a color go ahead but in this situation nail polish is perfectly suitable, or clear enamel from a local hardware store in a spray can.
Anything worth trying is worth failing at once or twice.
toroid winding robot star882 Parts 1 22nd June 2009 04:08 PM
need toroid winding wire for amp6 gychang Parts 4 31st October 2007 06:16 PM
winding multiple secondaries on a toroid??? Puggie Power Supplies 3 9th August 2006 05:58 PM
Repairing Scraped Winding on Toroid KT Parts 1 20th July 2004 02:47 PM
Start of winding in toroid matters? ftjandra Chip Amps 1 1st July 2004 07:13 AM
Page generated in 0.06232 seconds (71.86% PHP - 28.14% MySQL) with 10 queries
