Go Back   Home > Forums > Design & Build > Parts
Parts Where to get, and how to make the best bits. PCB's, caps, transformers, etc.
Old 19th July 2004, 06:27 PM   #1
pflodin is offline pflodin  Sweden
pflodin's Avatar
Default Hard to find transistor...
Hard to find transistor... Post #1
Hello all.
I'm trying to repair an Hill audio DX1500 Power amplifier and I need to find replacements for the originally used H001A B1 NPN Power transistors. I suspect that these transistors are (H001A B1) are ifact some kind of standard bipolar transistor vitch has gone trough a screening / matching process, but I'm not shure.
Anyon that has any info on this ?
Peter Flodin
Old 26th July 2004, 05:28 PM   #2
Default Transistors
We used to sell this amp ourselves. The transistors are sort of matched but its not that critical. The challence if finding any type of TO-3 device. Here is our engineering memo for this.
Replacing TO-3 output devices in older amplifiers
It is a problem replacing TO-3 devices as many are no longer available. However, electrically equal or superior devices are available in plastic “tab” packages like the TO-218. The large format plastic package of devices such as the 2SC1302 are meant to mount in locations where TO-3 devices were formerly used.
In order to replace TO-3 devices with a large format tab device you need:
- A suitable TO-218 or similar device. In the case of the RH D1500, this device needs to have a Vceo of 200V or better and an Ic of 15A or better
- An insulator washer for that replacement device. The old TO-3 one will not be suitable.
- In the case of a transistor where the mounting hole is not in a bare metal tab but is surrounded by plastic, you may need a solder lug where the mounting hole area is round and flat, not toothed.
To mount the replacement device you must:
- Bend the base and emitter leads (the two outer leads) 90° down exactly where the lead steps down in width so that the distance between the center of the mounting hole to the lead is 0.665” or 17mm
- Replace the TO-3 insulating washer with the new one. The alignment is such that the large hole in the washer will be around the TO-3 mounting hole furthest from the emitter and base leads.
- Insert the transistor. Note that at this time, the collector, or center lead will still be attached to the transistor and will not be bent. Be careful inserting the emitter and base leads as they are square or rectangular and the old leads were round. If a socket was used for the TO-3 device, you may have to force it a little and you may have to solder the pins in place to get a reliable connection.
- If the replacement device has an exposed metal tab, use the mounting screw you used for the TO-3 device to make the electrical connection for the collector. Then you can snip off the collector lead from the transistor. Please note that in some cases, the TO-3 device may have been connected to the other mounting hole. If this was the case, you may have to solder a short piece of insulated wire between the two mounting points of the TO-3 device.
- If the replacement device does NOT have an exposed metal tab and the mounting hold is surrounded by plastic, you may need a longer mounting screw. You will need to solder a flat solder lug to the collector lead and bend it over the top of the case so that the hole in the lug lines up with the mounting hole so that when you put in the mounting screw, the collector connection may be made. Please note that in some cases, the TO-3 device may have been connected to the other mounting hole. If this was the case, you may have to solder a short piece of insulated wire between the two mounting points of the TO-3 device.
If you have any questions about this, please contact the engineering dept. at Renkus-Heinz
Dan Fraser
July 12, 2001
Dan Fraser
Old 2nd August 2004, 07:33 AM   #3
burbeck is offline burbeck  United Kingdom
The transistors are MJ15024, they were supposidly matched at the factory, however i have had no problems with parts from same batch. one thing to look out for with these amps is the output 'base bias resistors' these need to be matched as accuratly as possible, measure a batch and use the best pair if you need to replace
regards
bob
regards
bob
Laser KSS-273 B, Hard To Find munja Digital Source 0 15th July 2007 09:16 PM
Hard to find transistor... pflodin Solid State 22 21st December 2006 06:46 AM
WTB hard to find transistors mmerig Swap Meet 1 24th January 2006 06:55 PM
Hard to find diode... Netlist Parts 7 4th February 2004 08:31 PM
Hard to find parts guitargully Parts 3 16th January 2004 04:57 AM
Page generated in 0.07944 seconds (76.30% PHP - 23.70% MySQL) with 10 queries
