| Parts Where to get, and how to make the best bits. PCB's, caps, transformers, etc. |
On a amplifier that needs a 65-0-65Vac / 800VA min, when I go get this power supply obviously the secondarys need to be 65v. But to run a stereo do power supplies come with two pairs of wires to power both boards. Or do I need to get two transformers? I know this may be dumb question to you experiance people but I am learning.
#2 |
the only "dumb" question is from one who doesn't speak.
you can do either. separate transformers and separate filter caps will make your amp into a "mono-block" one thing to make sure is that the current carrying capacity of the wire is adequate for the application. you can get #12 or #14 (and other guages as well) stranded copper in red, black, green from Home Depot -- |
#3 |
Does that mean then If I want one Power Transformer to power two channels (stereo) I need to get one rated at 1600VA with two secondarys coming out of it? Or when the kit describes the power supply requirement is that for two channels? Thank you for your reply.
#4 | |
Do you have a link to the kit? Im guessing its one 800VA transformer to power both the channels. |
#5 |
Deep down inside. |
| Hypex UcD 180AD + signal wires, Power Supply ST, Hypex Transformer TR100A | c10h12n2 | Swap Meet | 7 | 7th July 2007 03:55 PM |
| Designing secondary side power supply | darw82 | Power Supplies | 10 | 10th August 2006 09:05 AM |
| Transformer Wiring... 5 wires on secondary? | Parker_SMC | Solid State | 5 | 11th October 2004 03:10 AM |
| power supply from one secondary | Jared | Solid State | 12 | 13th September 2002 01:34 PM |
| Supply rail tracks / wires | Jamie F | Solid State | 2 | 26th January 2002 01:57 PM |
| Page generated in 0.07335 seconds (76.00% PHP - 24.00% MySQL) with 10 queries |
