Go Back   Home > Forums > Design & Build > Parts
Parts Where to get, and how to make the best bits. PCB's, caps, transformers, etc.
Old 19th July 2004, 02:17 PM   #1
alecwek is offline alecwek  Denmark
Default how does one recognise .....
hi i would appreciate any help i can get....
i need to build a power supply and i hahe two transformers from an old stereo....
th part no. are
tam b 0149
and
tam b 0205
anyone know where i can get information...power rating....primary\secondary tunrs.....output voltages???????
ive really tried searching around.....any help will be appreciated.....
i was thinking of testing the voltages but..then again this is a machine with a laser inside it so i am worried about the large voltages....any one got any suggestions???
Old 19th July 2004, 02:35 PM   #2
karma is offline karma  Canada
karma's Avatar
if its a cd player your somewhat safe just dont look into the laser
high voltages would be from the main's so avoid that. if you have a good volt meter you should be ok just take your time.
Old 19th July 2004, 03:24 PM   #3
hi thanks for the reply....nah its an amp ...with a cd player inside....the ICs used are able to take in 40v of supply voltage.....
worse still there are two transfromers....the one directly from the mains looks like a step up transformer.......so its got me a bit confused.....
the general rule of common sence is that u dont touch the mains....but what about transformers connected to the mains....and another things....should the black multimeter probe be grounded to th mains ground or should i use something like a water tap or radiater to ground it....thanks again
Old 22nd July 2004, 08:27 AM   #4
thanks for the help karma....i figured it out....so id like to end this thread.......
somebody can recognise this elna? netherlands Parts 4 23rd June 2009 03:18 AM
Anyone recognise these tubes... nickds1 Tubes / Valves 1 2nd December 2008 10:38 AM
Does anyone recognise this 12AU7? sharpi31 Tubes / Valves 2 28th January 2008 10:11 AM
Anyone recognise this amp? tubewade Tubes / Valves 7 16th December 2007 10:15 PM
Does anyone recognise this arm? dhaen Analogue Source 6 7th September 2003 08:59 PM
Page generated in 0.07138 seconds (73.20% PHP - 26.80% MySQL) with 10 queries
