| Parts Where to get, and how to make the best bits. PCB's, caps, transformers, etc. |
Dear All ,
In attampting to repair my switching power supply , I met with the following problems , I have no circuit diagram , Barco is not able to provide me one , the switiching power supply uses the following chips , TDA4601 . BU508A and BD237 plus one 11v zenor and several diodes , my problem being that the output voltages , 5 of them , drop to 1/3 when a loading is apply , for example , there is one output , @8-9 voltage , supplying votage to one 7085 for regulation , it drops to 2.6 volts and needless to say , nothing comes right ! I have replaced all said chips , zenor diode and test all capcitors & resistors , they are all OK . It is just one resister I am not sure , it should be a current limiting resistor as it is mounted 1/2" high from board , it is with the following color code : yellow / grey / black / gold / yellow* what confuses me being this 2nd yellow , what does it mean ? I have detached the resistor and it measured several Mega ohms , it seems not possible to have a current limiting resistor at this value but my knowledge is basic and I am not sure what being its purpose , it is situated in the major circuit path before the small transformer that output several voltages ! AS Barco had discontinued this TV demodulator for long and I am not able to get any support , I would appreciate helps & hints from you all where should I dig further into . Again , thanks in advance ! |
#2 | |
Hello
This resistor to the best of my knowledge would be 48 ohms with a tolerance of 5% the 5th band being the grade of resistor * disclamer - I WOULD DOUBLE CHECK - Jeff |
#3 |
It could be that the resistor got very hot, it went open - circuit, and the bands changed colour. This is a common failure in psu or power circuits. Get a second opinion on the colours then guess what the value should be. If it is raised above the pcb, then it is supposed to get warm, it is raised to avoid scorching the pcb. For current sensing, I would think a low resistance is most likely. I would draw out the circuit around that resistor to establish it's purpose, and improve on the accuracy of the guess. I've guessed the values of burnt resistors many times, and it works ok.
Good luck |
| help required with p3a | Mark25 | Solid State | 5 | 15th November 2006 11:41 PM |
| help required! | ross1976 | Analogue Source | 0 | 15th December 2004 10:28 PM |
| Help required | martioz | Swap Meet | 3 | 2nd February 2003 03:42 AM |
| Help required please | Andy G | Multi-Way | 0 | 29th November 2002 10:50 PM |
| amp required | b.m.turner | Solid State | 4 | 13th November 2002 12:37 AM |
| Page generated in 0.07544 seconds (86.18% PHP - 13.82% MySQL) with 10 queries |
