| Parts Where to get, and how to make the best bits. PCB's, caps, transformers, etc. |
I purchased a new ALPS Potentiometer Blue plastic casing, Dual/Stereo single metal shaft Type RH2702 , value 254 (250K) , clicked type .
It is brand new (maybe NOS). Anyone who can advise me on the following : Q1. Completed installation , it produced always a sharp cracks at the right channel at around 3O'clock position when I turn the shaft Left channel remains silent. What happened ? Is this defect ? Q2 Pin3 connected to input , Pin2 as output to Line Valve 12AT7 , Pin3 as ground. There is a pin4 unmarked , What is this for , I assume this is probably for a Loudness circuit. Q3 Have tried to search more info on this, but not available Anyone who can help me ? Thanks a lot Paul pyahya@cbn.net.id |
#2 |
diyAudio Moderator Emeritus
Q1 Probably a defect
Q2 Probably a loudness tap Q3 It seems to be available from some Japanese web sites, but as you say, it's not a standard Alps part number. Perhaps it's an OEM part. |
#3 |
I think they are just Chinese fakes, but some of them are supposed to be quite nice (the ones that are stepped, not just detented).
#4 |
Dear colleques
The ALPs is now OK. It appears a genuine old NOS . I have dismantled it, cleaned it rather harshly with a drop of HCl acid, extra fine sandpaper , cleaning fluid . All the resistors are OK and Its performing perfectly. Thanks for the response Paul pyahya@cbn.net.id |
#5 |
Did you buy them on Ebay?
Cheers Andrea |
#6 |
I believe I seen you say resistors if your pot has very small discreet resitors it is probably the chinese knockoffs I believe the legit Alps blue were only manufactured useing conductive plastic film which means it would have a smooth wiper
Jack Head |
#7 |
Dear Colleque
Yu culd be right at all. I have checked ALPS product web page, I culd not find a stepped (with resistors)pot meter as one of their products, the more I am also not a NOS expert (sort of a antique hunter) when it comes to select NOS things. But its the satisfaction I got from able to fix the problem, the sound is not bad at all, much better than the previous Noble. See ya. Paul |
#8 |
about this thread you will find a little overview about potentiometer and rotary switch
Potentiometer Overview - Alps, Penny+Giles, TKD and Vishay and more, what's your fav? |
| How to improve blue alps potentiometer | Tolu | Parts | 3 | 25th January 2010 02:53 AM |
| ALPS 100KAX6 MOTO potentiometer | uhcmos | Swap Meet | 2 | 11th November 2009 12:47 PM |
| WTB: ALPS RK27 250K Potentiometer | mrdon | Swap Meet | 14 | 6th August 2008 11:17 AM |
| Wanted: ALPS 20KAX4 potentiometer or equivalent | tvicol | Parts | 5 | 9th October 2007 06:13 AM |
| FS: some (ALPS/Dale 23 Step Attenuator )Potentiometer forsale | smilebear | Swap Meet | 12 | 18th July 2006 06:22 PM |
| Page generated in 0.09153 seconds (76.17% PHP - 23.83% MySQL) with 10 queries |
