Go Back   Home > Forums > Design & Build > Parts
Parts Where to get, and how to make the best bits. PCB's, caps, transformers, etc.
Old 10th July 2004, 06:12 PM   #1
Onvinyl's Avatar
Default op amp circuits: elegant wiring?
Hi all,
I read several dossiers about op-amp circuiting.
One mayor issue: keep every route as short as possible, especially feedback loops and decoupling. Because of the phyiscal dimensions of - for instance - the caps, you will end up in some sort of compromise.
Did you ever try to 'sandwich' an opamp circuit? You could bend the pins for +V and -V upwards and place a second board from above, so you can easily use even big caps, and have signal and feeding circuitry far from another. (I cannot make printed boards at home, so I'm doing p2p.)
Good idea or do I forget something here?
Maybe you have other tricky (or basic) ideas for elegant wiring?
Rüdiger
Old 10th July 2004, 08:29 PM   #2
janneman's Avatar
Location: Where Germany, The Netherlands and Belgium meet
I once tried something like that by standing all passive components on one wire and putting another board on top. I like the result, very compact, and you gain some more leeway in making a good layout. There's one big disadvantage: if you want to change someting afterwards, you either have to wring the component out in some way, which may damage it, or remove the upper board which is an even bigger pain.
Jan Didden
/Another new issue: Linear Audio Volume 3!
A safe and elegant way for soft-start Bakmeel Power Supplies 5 15th September 2010 07:47 PM
Beautiful and elegant concept design neil_kaye Analogue Source 3 2nd July 2009 06:32 AM
Research on tubes and circuits simple circuits Cazcotty Tubes / Valves 6 16th June 2006 12:50 PM
85 powersupply circuits 58 charge circuits gev Power Supplies 0 31st July 2005 11:27 AM
Elegant way to feed parallel data-input DAC chips ? Bernhard Digital Source 27 18th April 2005 09:28 PM
Page generated in 0.06999 seconds (67.74% PHP - 32.26% MySQL) with 10 queries
