| Parts Where to get, and how to make the best bits. PCB's, caps, transformers, etc. |
At a local surplus auction I purchased a palat of some sort of power supplies. I think they were for a co2 laser or something. I mainly got them for the rack mount cases, but there are a lot of capacitors inside and I was wondering if they have any potential for an audio application. They are Bosch capacitors, 40uF 2.5kV. Any ideas will be appreciated.
#2 |
diyAudio Moderator Emeritus
These could be used in power supplies for some of the more exotic transmitting triode / tetrodes
![]() I you can't use them yourself, i'm sure you'll get a good response at the "Trading Post". |
#3 |
Do capacitors have any sort of "shelf life", one of the decals on the inside of the case says it was made in 1985. Also, if I were to sell/trade them, what do you think they are worth?
#4 |
Capacitors do have a shelf life and yours look like there
almost 20 years old, I know most caps can be formed and most likely brought back to life, using a variac , for DIY they might be fine, However these are High voltage and need to be double careful also because there high voltage might be worth a fair amount of money. What would I sell them for, I'd need to see a picture and know a little more. Are they poly type, for motor start, Can with PCB's (also a big problem) Steve @ Apex Jr. |
#5 |
Here is a pic of the caps. Approximate dimensions are 4" diameter and 6.5" height. I had to significantly lower the res to attach it, so if you would like better pics I can email them.
#6 |
Can type, Here's my take...
If they do not say NO PCB's I personally couldn't sell them since I'm a bonifide business at least in Calif. As a person to the DIY market I don't know. If so I would get $5.00 to $7.50ea. If they do say No PCB's There worth $12.50 to $15.00............ Steve @ Apex Jr. |
| Need advise on this amp... | JojoD818 | Solid State | 20 | 18th December 2010 10:14 AM |
| Please advise | WunHungLo | Multi-Way | 4 | 28th June 2004 10:38 PM |
| Advise!! | jazzy | Digital Source | 0 | 12th February 2004 10:42 PM |
| Page generated in 0.07855 seconds (82.10% PHP - 17.90% MySQL) with 11 queries |
