Go Back   Home > Forums > Design & Build > Parts
Parts Where to get, and how to make the best bits. PCB's, caps, transformers, etc.
Old 7th July 2004, 07:19 PM   #1
Did it Himself
richie00boy's Avatar
Exclamation LM3x7 Datasheet Error?
I'm designing a PSU using LM317T/LM337T regs. The National Semiconductor datasheet states that the output voltage is calculated by:
Vout = 1.25 * (1 + (R2 / R1)) + (Iadj * R2)
where Iadj = 1.25 / R1
However, using this formula on the Typical Applications circuits, I cannot get anything like what voltage they say I should be getting.
This is further complicated by the LM337L datasheet stating that the output voltage is calculated by:
Which gives apparantely correct results.
Only this datasheet has the formula in this way, the LM317L, LM317T and LM337T all have the formula as in the first case. The L suffix is TO92 package and the T suffix is TO220 package.
Has anybody actually got any proven formula or values I can try? I built one using L suffix parts and according to the second formula and it worked fine, but I want to use T suffix parts now.
Old 7th July 2004, 07:22 PM   #2
jackinnj's Avatar
I(adj) is the current on the "adjust" pin, not the total current pulled through the device -- it's measured in microamps -- Nat Semi has min/max/avg values on the datasheet. -- something like 50uA
Old 7th July 2004, 07:41 PM   #3
Pjotr's Avatar
Hi Richi,
I_adj is indeed the current flowing out of the adjust pin. If you keep the recommended value for R2, 220 - 240 ohms, you can safely ignore I_adj and use the formula for the LM317L as well for the LM317T.
Cheers
Old 7th July 2004, 07:55 PM   #4
Electrons are yellow and more is better!
peranders's Avatar
Here is a spreadsheet which I made for the purpose.
Use it
/Per-Anders (my first name) or P-A as my friends call me
Old 7th July 2004, 08:24 PM   #5
Did it Himself
Thanks guys.
I was slightly misreading the datasheet and confusing Iadj with the whole current flowing in the programming resistors.
Old 7th July 2004, 08:32 PM   #6
peranders's Avatar
Good that you found out. In real life you can have R1 up to 1 kohms without problems. Iadj which cleary is stated is far less than worst case.
Improving the LM3x7 regulator circuit Geoff Power Supplies 158 8th January 2012 07:08 PM
KA3x7 vs LM3x7; is there a difference & bargain price smiler Parts 8 1st July 2009 06:22 PM
Regulated PS with LM3X7 ? kacernator Solid State 0 13th March 2009 04:04 PM
LM3X7 Supply zei Power Supplies 25 23rd December 2007 06:52 AM
LM3x7 HV regulating. w00t Parts 3 29th February 2004 09:42 PM
Page generated in 0.08637 seconds (78.14% PHP - 21.86% MySQL) with 11 queries
