| Parts Where to get, and how to make the best bits. PCB's, caps, transformers, etc. |
Hello all,
I have designed a portable amp which has a volume pot that I can no longer get from my current vendor, and need to get my hands on it desperately. If anyone can help me find a distributor for this pot I would GREATLY appreciate it. The specs are as follows: 10K Potentiometer with SPST Switch. PC Mount 1/2 watt. 10K Audio Taper. Mounts in a 9/32" hole. 1/2" x 1/4" round shaft. With mounting hardware. (Stock #: PT41) If you want to see what it looks like, you can see it at: http://www.smcelectronics.com/POT.HTM It is about half way down the page. If not, can anyone recommend a place where I can get my hands on a pot with a similar footprint?? Otherwise I have to redesign the PCB. Thanks, N |
#2 |
btw, I think it is made by NOBLE, and the numbers located on the side of the pot are:
15C10K and 9634 Thanks again, N |
#3 |
#4 |
You'll need to search for the replacement, but try:
www.newark.com www.alliedelec.com www.powell.com I'd believe Newark has something close enough. Good luck, GH |
#5 |
I have checked all of the above links with no success. Thanks so much for posting, but my search continues.
At this point I would settle for anything with a "similar" footprint. Thanks, N |
#6 |
The only thing I would do is check the other industrial suppliers. Someone should have something or have a non-oem replacement.
GH |
#7 |
"other industrial suppliers" ??? Have any ideas on who those might be?
thanks, N |
#8 |
try percyaudio
He has Alps Blackbeautry. |
| Desperately Seeking AK4395VF | si_jopie0382 | Swap Meet | 0 | 20th August 2008 08:26 PM |
| Desperately need SEAS P11RCY08H454 | richard pfeffer | Swap Meet | 0 | 23rd July 2007 06:43 AM |
| Desperately looking for SA-6e users' manual | Nounours18200 | Pass Labs | 18 | 17th March 2007 09:55 PM |
| Desperately Wanted !!! | ROCKMANDRAKE | Analogue Source | 0 | 28th October 2005 02:32 PM |
| Op Amp help needed desperately | segasonicfan | Chip Amps | 19 | 31st August 2005 04:19 AM |
| Page generated in 0.08611 seconds (78.16% PHP - 21.84% MySQL) with 10 queries |
