| Parts Where to get, and how to make the best bits. PCB's, caps, transformers, etc. |
Account Disabled
I bought an 8V motor with gear box used to drive battlebots off eBay. The thing has enough torque to turn the stepped attenuator I made (barely). The problem is how to control it. I'm using both a remote control reciever and a manual knob. The reciever chip can definitely not provide enough current to drive the motor. Can anyone suggest a circuit to control the motor, with signal at input for one direction, and at the other input for the other direction? I have some spare IRF610 that I can use.
Also, since I want the knob for manual control, I need suggestion for a mechanical linkage to do that. I was thinking something like in the attached picture (the knob must control the motor as it's too hard to turn the gear box from the output side). The two pushbuttons in the linkage in the picture sense when the user is trying to turn the knob. I know it looks complicated, but I couldn't figure out any other way to do it. BTW where can I get gears? I don't have the tools to make my own. |
#2 |
A nice way to drive a DC motor is 'H bridge'.
Look at the L293B or L293D (D coz including diodes) from STMicroelectronics. This chip accepts voltage levels up to 30Vdc and can deliver 600mA of current. One pin for the direction and another one to activate or not the motor. Really easy to use. It costs approx 2€ |
#3 |
An example using L293 :
http://www.me.umn.edu/courses/me2011...L293/L293.html Datasheet : http://www.st.com/stonline/books/pdf/docs/1328.pdf |
#4 | ||
Why not just a pair of pushbuttons (or a two way switch) on the faceplate? Remember, most times, K.I.S.S. works best. With the control you have the above picture, I can see it starting to rotate in one direction then overshooting where you are holding the knob, reversing, and then repeating this as it "hunts" for the null point. As far as gears, or other small parts, I'd look at small parts Inc. or any number of the surplus parts places on line. Keep us posted and Good luck! Tall Shadow |
#5 |
To get around the gear usually is done by implementing a limited slip clutch. Such can be obtained from Farnell or RS.
Magura
Everything is possible....to do the impossible just takes a little while longer. www.class-a-labs.com |
#6 |
Account Disabled
I hope I can find an H-bridge IC locally. I'd build a discrete one, but I have only N channel FETs and I'd need a voltage doubler to drive the upper ones.
Tall Shadow, there's no way to know the position of the volume control if I use pushbuttons. There's no problem with overshoot; you misunderstood my diagram. The motor turns both the attenuator and the knob. The user turning the knob can just turn it enough to engage one of the switches, and then the motor turns it until the user releases it. Due to the way the attenuator is used (in-between the balanced lines, this way I can use only two decks for balanced stereo), during a transition from one position to the other it will momentarily be at maximum volume. So I have to put a wheel and IR sensor to drive a muting relay. Talk about complicated volume control, LOL. |
#7 |
surprise surpirise...a H bridge can also be implemented with standard bipolar transistors...would it be cheaper?? i dunno...but most of us have more bipolars in our part boxes...
Kids in the back seat cause accidents...Accidents in the back seat cause kids... |
#8 |
Account Disabled
Well, the local store was sold out of L293 so I built a discrete MOSFET bridge, with small transistors to drive the FETs. Almost fried the semis, but it's working fine now. I'm gonna use an IR LED and sensor around a cardboard masking wheel to monitor for stops so the motor doesn't try to force the switch beyond its range, and another IR pair to mute between volume positions (during transition for a moment the volume will go to maximum due to the configuration).
| Can I use a computer PSU with a floppy/DVD motor drive TT? | morepower4me | Analogue Source | 19 | 25th March 2009 04:04 AM |
| Hard drive motor as a bearing | YAKI | Analogue Source | 3 | 3rd March 2009 08:17 PM |
| Floppy drive motor | BluesMagoos | Analogue Source | 20 | 13th June 2007 05:56 PM |
| servo motor for turntable drive | Mikewong | Analogue Source | 2 | 18th March 2004 08:51 AM |
| servo motor for turntable drive | Mikewong | Analogue Source | 3 | 4th February 2004 09:57 AM |
| Page generated in 0.10671 seconds (79.60% PHP - 20.40% MySQL) with 11 queries |
