Go Back   Home > Forums > Design & Build > Parts
Parts Where to get, and how to make the best bits. PCB's, caps, transformers, etc.
Old 4th July 2004, 07:24 PM   #1
Question Car chip amp???
I posted this in the CAR AUDIO section... probably the wrong section!..
so here is is again!.. sorry!..
" Help!.. need to source amp IC!
I've looked everywhere, well all that I know!..
I have a JVC KD-S611 car stereo with a nackered amp.
Everything else works, I just need a replacement IC.
The device number is Hitachi part HA13158A and is in a 23 pin tagged sil package.
I have tried to bodge a TDA8568Q device into the output stage, which I salvaged from another broken car stereo, however I think that one might be a bit dodgy!! coz it doesn't bloomin work!!
Both devices have the same package, however different pin configurations. This isn't a problem. If anyone could either supply, or point me in the right direction for either device, but preferably the original Hitachi amp, I would be eternally grateful!..
Cheers, Alex."
If there's an equivalent available, I'd love to know!..
Thanks again...
Old 5th July 2004, 02:10 PM   #2
dhaen is offline dhaen  Europe
diyAudio Moderator Emeritus
dhaen's Avatar
I've moved this to Electronics and Parts where it might get a bigger audience
Old 5th July 2004, 05:36 PM   #3
Cheers for that!..
I guess I'd have found the right subject header in the end.. Eventually!..
Old 5th July 2004, 06:34 PM   #4
joensd is offline joensd  Germany
Just recently changed one of those.
This Hitachi-IC is pin-compatible with these:
Pin to pin with HA13153A/HA13154A/HA13155/HA13157/HA13158
Have you searched with google?
YouŽll find the datasheet and a few shops that sell that IC.
jens
Old 5th July 2004, 07:06 PM   #5
Thanks for that.. I already have the data sheet for both devices, however I'm still having trouble sourcing this device in the UK!..
Will I have to mail order it from the USA?..
Is there anywhere in the UK who can supply small quantities of these.. I only need 1!! not 1000...
Thanks again...
Old 6th July 2004, 02:59 PM   #6
316a is offline 316a  England
316a's Avatar
Default Suppliers
Thanks again...
Hello ,
Try Cricklewood Electronics or Grandata
cheers
316a
Old 7th July 2004, 06:42 AM   #7
Thanks 316a! At last a "local" company to deal with!...
Both Cricklewood and Grandata have both devices in stock...
I guess I'd better go for the original Hitachi chip amp, coz the PCB's designed for it...
Is there a better amp I could use without too much bodging, or is this a pretty good device ?..
I dunno, open to suggestions...
Which Chip AMP you like most? dynabok Chip Amps 43 30th September 2008 08:55 PM
Pre-amp for chip amp wotsascott Chip Amps 23 30th April 2006 04:24 PM
First Chip Amp doomsweek Chip Amps 9 10th May 2005 01:55 AM
Best possible 10W from chip amp Robert_66 Chip Amps 14 2nd November 2004 11:43 AM
Hot chip! batkey Chip Amps 1 14th October 2004 11:54 AM
Page generated in 0.09249 seconds (76.69% PHP - 23.31% MySQL) with 10 queries
