Parts Where to get, and how to make the best bits. PCB's, caps, transformers, etc.
Black gate PS capacitors
Old 2nd July 2004, 04:52 PM   #1
BHD is offline BHD  United States
BHD's Avatar
Send a message via Yahoo to BHD
Question Black gate PS capacitors
I have questions about these. People say they're the "best" caps for tube amp power supplies, but I've also heard that they take a long time to burn in (no problem) and that they require 20-40 hours each time the amp is turned on to become "charged" before they sound their best.
This would be problematic. Many people leave their solid state gear on all the time, but it's not really advisable for tube gear. It would also be silly to expect people to warm up their gear that long. Anyone have experience with the burn in and charging requirements for these caps?
I'd also like to hear from people that have used them if they really live up to the hype.
My religion is the golden rule. The only time it's forsaken me is when I've forsaken it first.
Old 2nd July 2004, 05:03 PM   #2
analog_sa is offline analog_sa  Europe
analog_sa's Avatar
Hi
I can't really answer your question as i only use BGs in low voltage apps (a wild guess why?) but i find their continuous need for break-in to be seriously exaggerated. Once they settle they sound good to me even after a prolonged period of rest.
With tubes i use Cerafines, which share a similar reputation re the break-in and IME also sound fine after the initial break-in.
Then again, my ears don't seem to be too sensitive to warm-up effects and i normally start listening within five minutes of powering up.
Old 2nd July 2004, 06:09 PM   #3
BHD's Avatar
Thanks for the info.
If you don't mind, have you compared standard 'lytics to the boutique parts in the same circuit? If so, were there any differences/improvements?
Old 2nd July 2004, 08:23 PM   #4
analog_sa's Avatar
On many occasions, both in SS and tube. The differences are immediately obvious in A/B comparisons and that's why i usually prefer using boutique parts. In long term, everyday use though, the boutique parts don't seem to significantly contribute to my musical enjoyment. Factors such as synergy seem more important.
Old 2nd July 2004, 10:03 PM   #5
fdegrove is offline fdegrove  Europe
diyAudio Senior Member
fdegrove's Avatar
Tsskkkkkkkkkk....Someone's been wildly exaggerating ...
Actually once they're broken in they don't need all that much time to sound their best, say an hour or so.
Provided you use the amp regularly it won't be such a hassle.
(Just noticed Analog_sa is saying the same thing so...you just have a second opinion now)
Either way, if you want to avoid the BGs breaking-in period in the PSU I can recommend ASC polypropylene in oil and Solen SCR MKP caps for this application.
I'd still recommend the BG for cathode bypass duties as they're superior to any other cap I've ever tried in that position.
Frank
Old 2nd July 2004, 10:50 PM   #6
BHD's Avatar
Thanks for the second opinion and the advice.
Yeah, it didn't seem to make much sense to me, since the Black Gates were supposedly designed with tube power supplies in mind. What made me wonder was that in almost all my back issues of Sound Practices and such, all the DIY amp projects seemed to use Cerafine power supply caps. Everyone paid lip service to the black gates, but no one actually used them, despite their reputation.
It must have been the price, I guess.
My second choice was going to be the polypropylene in oil ASC caps. I think I'll go with them on this project.
Old 2nd July 2004, 11:12 PM   #7
fdegrove's Avatar
Hmmm...guess so.
Plus the fact that in those days these caps were even more expensive and nobody was too keen on testing the water at those prices, I suppose...
Nowadays the Elna have practically disappeared and BGs've become the norm.
They also share te same advantages of longevity the filmscaps do so all in all that kind of justifies the rather steep investment.
Frank
Old 3rd July 2004, 01:57 AM   #8
Peter Daniel is offline Peter Daniel  Canada
Peter Daniel's Avatar
Black gate PS capacitors Send a message via AIM to Peter Daniel
Recently the price on those caps dropped by at least 20%.
I use them wherever I can, but I find type N much better than STD grade (it is also 3 times the price). I didn't find a better electrolytic than BG N and that cap sounds better than majority of film caps. I'm using them in coupling applications and can't complain at all. Although those caps are non polar, the orientation with regards to outer foil is still imporatnt and should be observed for best sound.
STD version can sometimes sound too bright or a bit forward, but when properly balanced with a rest of the circuit it is very good sounding. Type N is more smooth and 'organic', still possesing the presence and detail, without any brightness and fatigue. NX type is softer sounding than N and I use it only when cost is an issue.
To order kits contact me through forum mail.
Old 3rd July 2004, 04:05 PM   #9
rdf is offline rdf  Canada
rdf's Avatar
I recently tried a pair of N-types as cathode bypasses in a Mullard 3-3 prototype (yes, my first DIY though my regular listen for the last 20 years was an MC240) and was blown away by the slow improvement over the next couple of days. One question: how do you determine foil end on a non-polar?
Old 4th July 2004, 04:17 PM   #10
Short lead stands for the start of the foil (inside foil). If the leads are already trimmed, the printing "Non Polar" is always on a side of a shorter lead. I find them to sound better, when the outer foil is on the ground side.
Black gate PS capacitorsHide this!Advertise here!
FS: Black Gate capacitors wimdehaan Swap Meet 6 1st August 2009 06:18 AM
WTB: Black Gate capacitors Mario Pankov Swap Meet 0 20th May 2009 03:10 PM
Black Gate capacitors catcando Parts 3 4th February 2008 09:36 PM
black gate capacitors! lanchile07 Chip Amps 5 12th November 2007 12:01 PM
FS: One Lot of Black Gate STD Capacitors mrdon Swap Meet 1 30th October 2007 12:45 AM
