Go Back   Home > Forums > Design & Build > Parts
Parts Where to get, and how to make the best bits. PCB's, caps, transformers, etc.
Old 2nd July 2004, 03:12 AM   #1
Default Daisy-chaining power cables
Hi, I am planning to build seven gainclones each in a seperate enclosure with a 200va toroid. Would it be bad to daisy-chain the power cables from the first amp to the second, second to the thirds, third to the fourth, etc.? That way I don't need seven outlets and save on cable clutter. Right now I am planning to use Neutrik Powercon connectors. The other choice would be to put all the amps in one huge enclosure. Any comments/suggestions? Thanks.
--Ferdi
Old 6th July 2004, 04:41 PM   #2
benny is offline benny  Australia
benny's Avatar
Send a message via MSN to benny
yes, this is fine, as long as the cable and mains plug used before the splitting point can handle at least 12A current this is fine. all seperate sockets are is just // conections to the same source, so creating // conections here is no different to using seperate sockets.
Old 6th July 2004, 05:21 PM   #3
tiroth is offline tiroth  United States
No, they are in series. Each amp down the chain will have it's PSU progressively modulated by the previous ones. I think it will work out ok though because we are talking about mains; as long as each amp has it's own transformer the impedance of the wiring should not be a large factor compared to the impedance from the power company.
If we were talking about high power amps I would worry but we aren't.
Old 8th July 2004, 03:46 AM   #4
imix500 is offline imix500  United States
Proud Union Member
imix500's Avatar
The Powercons are great. If you find a supplier with the grey (output) panel mount type, load up on them. They are backordered from Neutrik all the time. Btw, if they are going to be plugged/unplugged a lot get youself a few spares. Neutrik is still getting the bugs out of these and is having a few issues with reliability after repeated make/unmake cycles.
daisy chaining an electronic crossover qguy Subwoofers 5 14th January 2007 01:53 PM
DAISY Display Kit sebastian_s Digital Source 5 16th October 2006 09:37 AM
Harman Kardon A-401 Preamp Chaining?? LONGHAULTRUCKER Solid State 0 5th February 2005 08:03 PM
Daisy chaining 2 PCM2902's djd4n Digital Source 4 2nd August 2004 03:03 AM
Daisy-chaining transformers Wingfeather Parts 13 13th May 2003 11:30 AM
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2013 DragonByte Technologies Ltd. (Resources saved on this page: MySQL 30.00%)
Copyright ©1999-2013 diyAudio
