Parts Where to get, and how to make the best bits. PCB's, caps, transformers, etc.
got some interesting junk
Old 27th June 2004, 02:54 AM   #1
yosh is offline yosh  United States
Default got some interesting junk
Hello all
I am trying to learn all this tube amp stuff and have finally decided to go out and buy a few odd and ends that i may be able to learn from.the least i will learn is how different components are put together.i really don't want to spend alot of money on valuble components when i don't know what i am doing.
So i woke up this morning to a beautiful sunny day and as usual was asked to go out to the garage sales,this time i actually went.and i have found a few interesting subjects to take apart.
I came across three peices two are identical.Here is what they are as far as i can tell.
the two that i found together are labled:LH research Dyna-MITE
input:504VA
42-56VDC
output:28V,9A
there are two adjusters on the front,one says V the other says I.
inside are 2 small transformers and two matched pairs of big mallory capacitors.
the other peice i found was a DC power supply(very freekin heavy),on the front it has four sets of binding post they read as follows +12VDC,-12VDC,+15VDC and -15VDC.Inside i found two matched pairs of LAMBDA regulated power supplys.both have fairly heavy transformers and very big Lambda capacitors(at least to my eyes),with one adjustment for VDC.
The larger of them is labled:input 105-132V 57-63Hz
Max rating
9.5A@40C
8.6A@50C
7.4A@60C
4.8A@71C
with the adjuster :15+-5%VDC
the smaller says:input 105-127 VAC or 210-250VAC}47-63Hz 255W MAX
12+-5%MAX rating
8.5A@40C
7.2A@50C
5.9A@60C
4.2A@71C
the adjuster just says VDC.
Now the question,What the hell are these things, what are they for and finally can i figure out what these transformers are with no lables,I just realized that the smaller power supply has a lable but still nothing i recognize.
any help would be greatly appreciated,even if all you can tell me is what one of these numbers makes reference to.
thanks all
YOSH
Old 27th June 2004, 04:33 AM   #2
Sch3mat1c is offline Sch3mat1c  United States
Sch3mat1c's Avatar
Send a message via ICQ to Sch3mat1c Send a message via AIM to Sch3mat1c
Please move to SS. 50V has no place here.
Some nice equipment though, I'd be glad to take that useless junk off your hands...(hint hint)
Tim
Seven Transistor Labs, LLC
Projects and Resources / Electronic Design and Consultation
Old 27th June 2004, 10:01 AM   #3
dhaen is offline dhaen  Europe
diyAudio Moderator Emeritus
dhaen's Avatar
It think "Electronics and Parts" is more appropriate
got some interesting junkHide this!Advertise here!
My DIY UcD amp from the junk box acid_k2 Class D 38 3rd September 2012 06:01 PM
I found more junk! Magnetmaz Tubes / Valves 9 28th December 2007 09:49 AM
New Chip Junk classd4sure Class D 85 20th September 2006 09:24 PM
Tip for Junk box Zen PSU? SM7UYJ Pass Labs 2 4th April 2005 10:57 PM
Just got new junk from my friend Giaime Solid State 29 22nd March 2005 01:29 PM
