Parts Where to get, and how to make the best bits. PCB's, caps, transformers, etc.
Just had a power cap blow!
Old 24th June 2004, 05:38 AM   #1
azira is offline azira  United States
Default Just had a power cap blow!
Interesting thing happened tonight. My buddy and I were glueing together a coffee table for his place and listening to some tunes on a GC I've had thrown together on my bench. Anyway, suddenly we hear a pop and a psheeewwwww like air coming out of a tire. Look up and one of my power caps (20,000uF powerlytic rated at 65 Volts) is spewing a 7ft cloud of smoke like one of those fogger bug killers you use in your living room. Strange thing is music still played as well as before but I ran over and shut off the power as quick as I could. About 10 minutes later after we finished the glueing, I went over to unplug the cap and toss it and noticed that it was very hot to touch and the bottom had rounded out like if you freeze a soda can.
Shame that I lost a cap, but I bought them from the Trading post here and I knew they had been on the shelf for a while. Still, been using it for about 3 months with no problems.
Anyway, does anyone know exactly what that smoke consists of? I'm trying to think of what's in the cap that would smoke like that. We opened some doors and ventilated just in case..
Danny
Old 24th June 2004, 06:06 AM   #2
karma is offline karma  Canada
karma's Avatar
electrolyte i have poped allot in the past and im still here. it just smells bad
Old 24th June 2004, 06:45 AM   #3
Sch3mat1c is offline Sch3mat1c  United States
Sch3mat1c's Avatar
Send a message via ICQ to Sch3mat1c Send a message via AIM to Sch3mat1c
I had one go before and it made a nice fog but didn't smell, that I recall... different mix I guess.
What happens is it overheats and being the electrolyte is more or less water based, it boils and boiling water + confined space = what, children? A steam boiler...
Fortunately, most caps have those perforations on them so they blow in one direction, spewing not as much crud as say, the whole can exploding...(which used to be a problem in some old tube amps... )
Tim
Seven Transistor Labs, LLC
Projects and Resources / Electronic Design and Consultation
Old 24th June 2004, 06:56 AM   #4
karma's Avatar
yes the old ones go off like a starter cap for explosives
nothing left but paper
Old 24th June 2004, 07:01 AM   #5
Yeah.. it blew through a freeze plug in the top... Didn't smell though.
Old 24th June 2004, 07:09 AM   #6
karma's Avatar
not all do i only had one that did.
Old 24th June 2004, 08:26 AM   #7
LineSource is offline LineSource  United States
LineSource's Avatar
Default WHAT BRAND OF CAPACITOR IS MOST RELIABLE
What brand of power supply capacitor is the most reliable? Has the longest rated lifetime?
Is is better to use a large number of small caps, or a few big caps for the power supply of an amplifier output stage?
Some designers use a large number of small modest size capacitors, like 48 at 8,200 uF each. Small capacitors like Panasonic are rated 10,000 hours MTTF. These can be soldered right on the PCB if dual sided 4 ounce copper is used and provide low resistance and inductance, plus a clean design.
Some designers use a few large size computer grade capacitors, like 6 at 68,000 uF each. These require bus bars and/or wires that add parasitics and make a true star ground complicated. Computer grade caps are typically rated > 20,000 hours MTTF, but some say that multiple on-off cycles can dramitically reduce this .
So, what is the best way to build a power supply for an amplifier output stage, and what capacitors are the most reliable?
Old 24th June 2004, 08:33 AM   #8
I would suggest that if you were to parallel many smaller sized caps, then if one were to fail but not short, it would still act as a capacitor of smaller size. In addition, all the ESRs of the caps would be reduced because they are in parallel.
If the a cap fails and shorts, you're screwed anyway whether you have one or many..
Old 24th June 2004, 08:36 AM   #9
Jennice is offline Jennice  Denmark
Default just wondering...
Isn't it the high inrush current that eats away the life time? I mean... these peak currents (if you don't use limiting resistors) can be impressive, but way beyone the ripple current rating of a cap.
Any other suggestions?
Jennice
I get paid to break stuff. My g/f gets paid to play with children. Life is good.
Old 24th June 2004, 08:47 AM   #10
peranders is offline peranders  Sweden
Electrons are yellow and more is better!
peranders's Avatar
Life time?
How the cap is designed, choice of electrolytics etc.
The temperature inside.
Other stress like to large currents.
I have seen RIFA caps with 250 000 hours life time!
10000 hours is only one year in 24/7 usage!
It's better to have many small caps but it costs more and take up more space.
Conclusion: Keep the caps cool and use them within their specifications and notice the mounting positiion, up right or horisontally, read the datasheet to determine this.
Which brand is the best? Mosts brands keep their promises but some brands are better. I have noticed that Rubycon is better than ERO Roederstein and Lelon is almost as good as Rubycon. RIFA is one if the best.
I'm also pleased with Elna, Jamicon, Sic-Safco, Frako and many more.
/Per-Anders (my first name) or P-A as my friends call me
Group buy: SSR03 Super Regulator Power Supply. Sign up HERE 72 pcb's ordered, 72 paid. Still possible to sign up.
Just had a power cap blow!Hide this!Advertise here!
NAD fuses, slow blow or fast blow? AllCaster Solid State 3 25th October 2009 07:11 PM
Setting power amp so speakers don't blow (help a novice) drumstruck Solid State 0 29th May 2009 03:23 AM
Blow up once, Blow up twice and Blow up somemore S.C Chip Amps 14 6th March 2005 01:09 AM
Will This Blow Up? Trout Instruments and Amps 8 6th February 2005 01:52 PM
Two power supplies blow fuse h_andree Chip Amps 14 4th September 2004 03:09 AM
Copyright ©1999-2017 diyAudio
