Go Back   Home > Forums > Design & Build > Parts
Parts Where to get, and how to make the best bits. PCB's, caps, transformers, etc.
Old 15th June 2004, 01:37 PM   #1
multiplexor's Avatar
Send a message via ICQ to multiplexor
Default NEED help figuring out this coin sensor / switch thing!!! :-)
Hey guys!
I need help!!!
I want to know what the symbol is in this image, on the left side, in the oval... I'm assuming photodiode type thing....
It's for a coin sensor... I'd like to know if I cross wires 2 and 4, if it will complete the circuit and trigger a fake coin...
Thanks a million!!!
"There is generally one person in every situation you must never under estimate the power of."
- Quote by: Ken Kessey.
Old 15th June 2004, 02:03 PM   #2
to help out... i Believe this machine is from the late 70's....
could it be?
it's a maytag commercial washing machine...
Old 15th June 2004, 02:19 PM   #3
jneutron's Avatar
I make the assumption that the coin will interrupt the light between the led and the photo-transistor..
Disconnecting wire 1 will do the same thing.
John
Old 15th June 2004, 02:31 PM   #4
Looks to be a LED to Photo transistor set up.
I don't think You would get what you want,by crossing wires 2 & 4.
What you need to do is to pulse the power through the LED and trigger it in to thinking it "Sees" a coin.
Good Luck & let Us know what happens!
Tall Shadow
Old 15th June 2004, 02:41 PM   #5
Tall Shadow
pulsing it like jneutron mentionned, where i disconnect and reconnect it?
or?
Oh, and i'll definetely let you know how it goes!!!
Old 15th June 2004, 06:22 PM   #6
Devil_H@ck's Avatar
Send a message via ICQ to Devil_H@ck Send a message via AIM to Devil_H@ck Send a message via MSN to Devil_H@ck
jneutron didn't say to pulse anything, he said to disconnect 1. And I think he's right, it looks like the most normal thing to me. Having a dropped-in coin actually generate a pulse would be harder than having that led & photo-transistor thing.
Website: http://members.lycos.nl/anthonyvh
Old 15th June 2004, 06:48 PM   #7
coolies
I will possibly give this a shot...
It's tricky... I've posted this on a couple other forums and not one person has really given the same response....
some say disconnect 3 and 6... some say you can't because it's digitally timed... though being that the machine is so old, I figure it's probably not...
I like the idea of disconnecting and quickly reconnecting wire 1...
It sounds very resonable!
Old 15th June 2004, 06:52 PM   #8
jneutron's Avatar
The circuit can work in one of two ways..
The first, is the led shines directly on the transistor, and it remains on...when a coin passes between the two, it interrupts the light beam, and the transistor turns off. This is the more reliable method, as the surface of the coin does not matter. To fool the electronics, either disconnect one of the transistor leads or the led lead.
The second method is to have the led shining away from the transistor, and then the coin reflects the light to the transistor, turning it on. This is a less reliable method, as it requires the coin be shiny enough to reflect the beam, but it does allow a more compact led-transistor package, if cost were an issue. To fool this one, shorting the emitter/collector together will fool the circuit into thinking the transistor was on.
Either technique can be spotted by the geometry of the mechanical setup.
John
Figuring out how many watts I need Chepo Tubes / Valves 6 9th June 2009 12:43 AM
Need help figuring next upgrade Shike Everything Else 0 22nd June 2008 04:37 PM
6SN7 coin base tubes Original Burnedfingers Tubes / Valves 3 18th May 2008 01:00 AM
Figuring out speaker problems bg4533 Multi-Way 4 22nd August 2005 05:38 PM
Anyone remember the coin tweak? JCoffey Multi-Way 32 17th December 2003 08:37 PM
Page generated in 0.09501 seconds (81.38% PHP - 18.62% MySQL) with 10 queries
