Go Back   Home > Forums > Design & Build > Parts
Parts Where to get, and how to make the best bits. PCB's, caps, transformers, etc.
Old 13th June 2004, 02:33 PM   #1
janneman's Avatar
Location: Where Germany, The Netherlands and Belgium meet
Default Complementary med pwr transistors?
Hi all,
I am looking for complementary med power transistors, min specs 100V min Vce, Icont min 100mA, Pav min 3W, prefarably no SMD, TO220 would be fine, I've got enough heatsink real estate.
Since I grew up with BD139 (which doesn't meet the Vce spec), and the BD239 (which has rather low Hfe), I'm a bit out of touch with the newest devices. They will be used in current mirrors in my new power amp. Any recommnedations?
Jan Didden
Old 13th June 2004, 02:56 PM   #2
Tube_Dude's Avatar
Default Re: Complementary med pwr transistors?
Hi
Hitachi 2SB649 / 2SD669
Case TO-126 - 180 Volts- collector current 1,5A-Power dissipation 20 W- hFE (60-320)- fT 140 Mhz
or Toshiba 2SC3298B / 2SA1306B
200Volts- 1,5A- 20W- hFE (70-240)- fT 100 Mhz
or Toshiba 2SA1837 / 2SC4793
230 V - 1 A- 20W- hFE (100- 320)- fT 70 Mhz
Jorge
Old 13th June 2004, 02:58 PM   #3
li_gangyi's Avatar
how about the MJE340s??
Kids in the back seat cause accidents...Accidents in the back seat cause kids...
Old 13th June 2004, 02:59 PM   #4
janneman's Avatar
Jorge, muchos gracias!!
Jan Didden
Old 13th June 2004, 03:01 PM   #5
janneman's Avatar
I'll check. Thanks.
Jan Didden
Old 13th June 2004, 03:17 PM   #6
li_gangyi's Avatar
datasheet at
http://www.onsemi.com/pub/Collateral/MJE340-D.PDF
V(ceo) at 300V min...should fit your bill
Old 13th June 2004, 03:20 PM   #7
janneman's Avatar
Yes, looks good. I will probably need to buy a 100 or so and select them, because they are for current mirrors, and they need to swing close to the supply so I don't want to use emitter degeneration to force an Ic match. I have no idea how close they would be in Vbe in a same-batch.
Jan Didden
Old 13th June 2004, 03:25 PM   #8
Tube_Dude's Avatar
datasheet at
Strange!...not a word about fT in the data sheet...
Jorge
Old 13th June 2004, 03:55 PM   #9
sam9 is offline sam9  United States
sam9's Avatar
TIP31c 7 TIP32c. I think some other "TIP" series excluding the Darlington's would fit the requirements. A bit old fashioned but they do the job.
One advantage of the TO-220 package vs. TO-126 is for some applications the larger collector plate on the back provides sufficient dheat dissapation without adding a clip on sink.
Old 13th June 2004, 04:57 PM   #10
janneman's Avatar
Yes, thanks, I forgot those, I have used these many years ago, I seem to remember that they had relatively low Ft and *very* low Hfe above a 100 mA Ic. I'll check it.
Jan Didden
Biggest Complementary Transistors EWorkshop1708 Solid State 31 13th June 2008 10:43 PM
can't find good complementary transistors keantoken Parts 28 13th September 2006 12:22 AM
High-Voltage 350-400V Complementary Transistors for VAS :needs info ? Workhorse Solid State 9 30th August 2006 02:37 AM
complementary transistors needed sss Solid State 2 25th October 2003 02:20 PM
Page generated in 0.11638 seconds (77.91% PHP - 22.09% MySQL) with 11 queries
