Go Back   Home > Forums > Design & Build > Parts
Parts Where to get, and how to make the best bits. PCB's, caps, transformers, etc.
Old 14th June 2004, 01:34 PM   #21
hjelm is offline hjelm  Sweden
hjelm's Avatar
Jan:
Couldn't you use a cascode if the Vce is too big.
When you use currents there might actually be a gain in it.
Set the base at a fixed voltage and the emitter towards the mirror, gives the mirror less Vce voltage swing to work against as well.
I am not too good at this but it seemed to work in my iv stage although i didn't get any gain in using it, no Vce problem.
/Hjelm
Hjelm
Old 16th June 2004, 12:15 AM   #22
jcx is offline jcx  United States
don't dismiss emitter degeneration without looking at some #
roughly the improvement in matching, linearity, output z is porportional to the amount of local feedback
~= V(Rdegen)/26mV
so even a few hundred mV arcoss the degeneration Rs could improve things to a useful extent with a low voltage burden - certainly much less than 600mV
Old 16th June 2004, 08:18 AM   #23
Electrons are yellow and more is better!
peranders's Avatar
http://www.analog.com/UploadedFiles/...255MAT03_c.pdf
http://www.analog.com/UploadedFiles/...7SSM2220_b.pdf
Please note that SSM2220 comes in SO08 finally! and also to a decent price.
Check at the end of the datasheets.
/Per-Anders (my first name) or P-A as my friends call me
Biggest Complementary Transistors EWorkshop1708 Solid State 31 13th June 2008 09:43 PM
can't find good complementary transistors keantoken Parts 28 12th September 2006 11:22 PM
High-Voltage 350-400V Complementary Transistors for VAS :needs info ? Workhorse Solid State 9 30th August 2006 01:37 AM
complementary transistors needed sss Solid State 2 25th October 2003 01:20 PM
Page generated in 0.07285 seconds (66.14% PHP - 33.86% MySQL) with 11 queries
