| Parts Where to get, and how to make the best bits. PCB's, caps, transformers, etc. |
Account Disabled
I'm planning to use one of the 23/24 position C7 series Electroswitch from Digikey for volume control. However, I want to motorize it so I can hook it up to the remote control receiver. The remote decoder IC outputs pulses, so I need some help figuring out how to turn the attenuator a step each pulse. Any suggestions how to do this?
#2 |
It might be easiest to use a small servo and a pic or other similar microcontroller to turn the attenuator.
#3 |
Account Disabled
I found a small motor/reduction gear assembly that has enough torque and low enough speed. But how do I disengage the motorization when I'm doing manual rotation of the knob? (obviouisly the reduction gear would not allow me to rotate the knob with any reasonable force).
#4 |
If you make the motor driver outputs float (as opposed to grounding both) it shouldn't be too hard to turn by hand. If it still is too hard to turn I would suggest you find a different motor assembly.
#5 |
All Electronics sells a motorized dual pot for about $6. It is a dual 20k linear Alps pot. Maybe you could change out the pot elements for log units.
If it sounds good... it is good! |
#6 | |
The only tricky bit was drilling the holes in the center of the shafts so I could join them. This would have been easy if I had a lathe but careful centering in the drill press resulted in suitable accuracy. |
#7 |
Account Disabled
The pot motor hasn't got nearly enough torque to move the large switch I have. I used a larger motor with a gearbox that results in about 10-12 rpm at 8V. Couldn't find a driver IC locally, so I built a discrete H-bridge with BJTs driving MOSFETs. Probably overkill, since it managed to drive a garage door opener motor
#8 |
Account Disabled
#9 |
Could some explain to me the point of a remote volume control?
#10 |
Account Disabled
Are you serious?
Most commercial gear has remote controls. It's not just the volume control, the whole DAC can be controlled remotely, power on/off, input selection, output selection... The point is the same as for any remote control -- so you don't have to get up and go to the equipment to change something. If a TV should have remote control, why wouldn't some other piece of A/V eqiupment? |
| Attenuator | chuka | Solid State | 1 | 24th May 2009 04:57 AM |
| De-motorizing a motorized volume | KKG | Parts | 3 | 7th March 2009 11:48 AM |
| P-1.7 attenuator | pinco | Pass Labs | 1 | 17th October 2006 08:48 PM |
| Attenuator | Raka | Chip Amps | 8 | 13th June 2003 08:14 PM |
| attenuator for A75 | Vlad | Pass Labs | 0 | 8th September 2002 09:17 PM |
| Page generated in 0.09703 seconds (73.30% PHP - 26.70% MySQL) with 10 queries |
