Go Back   Home > Forums > Design & Build > Parts
Parts Where to get, and how to make the best bits. PCB's, caps, transformers, etc.
Old 11th June 2004, 07:28 AM   #1
Jean is offline Jean  United States
Jean's Avatar
Send a message via AIM to Jean
Default when I was younger...
I remember when I was 12-15 and played with EI transformers , I was trying to make some sort of high voltage transmitter to affect my parents tv in the next room . So I was playing with a transistor based relay circuit, timed to click every few seconds and instead of turning a light bulb on I had it turn the 2nd coil on bunch of different transformers and used the primary with some long wires for "antennas" .
Stupid huh ?
Feel free do add your own stories
left lane is for passing, slower traffic keep right please.
Old 11th June 2004, 10:46 AM   #2
Banned
We, (a friend of mine and me) made a chain of transformers to get a high voltage, and shorted the last winding with a relays. The relay was controlled by some multivibrator to turn on and off with some Hz, so it made a lot of sparks between contacts. It was a pretty marconi style transmitter, but not for long as we had not many relays and they lived only a short time in this ciruit....
Old 11th June 2004, 01:10 PM   #3
Circlotron's Avatar
At about age 11 or so, I got an old output transformer from a radio (ideal as it turned out because it had a gapped core and so it worked well in flyback mode) and put the primary in series with a small electric motor running off a 6v battery. The motor commutator interrupting the current worked just fine. I could draw a continuous 5mm arc from the secondary wires of the transformer.
Best-ever T/S parameter spreadsheet.
http://www.diyaudio.com/forums/multi...tml#post353269
Page generated in 0.06625 seconds (67.58% PHP - 32.42% MySQL) with 9 queries
