| Parts Where to get, and how to make the best bits. PCB's, caps, transformers, etc. |
I am going to make a gainclone but I am not sure how to choose a good capacitor for good sound quality. I have made a PIMETA headphone amp and know some good brands like Elna starget/cerafine , Panasonic FC series etc but I see some gainclones here seem to have big exotic looking ones
I am wondering what are some good brands and model that is available via RS components or Farnel/newark. And where did you get yours if they are not readily available? How do you pick them? I got 5 of these today from a scrap metal yard for $2. Written on them: Roe brand ELKO - EYM/A 10,000MFD -10/+50% 100V- -40...85 degrees C 433/3.85 W-Germany Pic attached Any good? (I have searched for this model/brand) Thanks |
#2 |
Many people here will tell you to go for something between 1000-2000uF.
Blackgate or similar expensive capacitors. I would try the ones you have out, but also try something with a lower capacitance (panasonic, BC, anything decent). Then decide which sound you like best. Personally I have some 5k and 20k uF ones, when I finish off my amp I will test to see which sound better. I dont really want to go buy exotic anything at this point. Oh yeah and make sure you test those out as well. Connect a resistor in series and measure the voltage across it (should drop to very low), or measure the current? I have found both methods from searching this forum. |
#3 |
The more capacitance you have in the supply the better...it just takes up more room.
If those caps are still good they are fine. Blackgates and other similar "magic" capacitors are nothing but a waste of money IMO. Especially in the power supply, the "sound quality" of a capacitor is insignificant. The gainclone has few/no capacitors in the actual audio path...therefore why should you drop $25 or more on your 1000uF Blackgate when it is not even in the audio path (where it matters )? And therefore can not affect the actual audio signal at all? Bottom line is that your caps are more than adequate and if you decide you don't want them and they work I'll buy them. -Matt |
#4 |
I think these are fine old Roederstein caps. They have a good "Reputation"
The question is how old they are, and if they are still allive. The age might be describt in the 6th line, but I am not sure! Maybe you cold measure them before using. PS: I think you made a realy fine catch at the scrap yard |
#5 | |
diyAudio Moderator Emeritus
Panasonic FC is a good choice and cheaper than BG. When the Roederstein caps are more than 10 years old I would not use them considering the low prices on new quality caps. If you're on a budget and decided to use them anyhow please leave them at a low voltage ( 5V or something ) supply with a large resistor ( 1M, 470 kOhm or so ) in series for a day or so. Then turn up the supply to 20 V and leave it for a day like that. If there are any signs of "leaks" in the rubber seal at the top I would advise you to discard them. Do not forget to discharge the cap with a 100 Ohm resistor before using it. !!! Connecting old electrolytic caps that have been stocked/not used for a long time directly at their rated voltage may let them explode, you've been warned !!! When stocked for a longer time oxidation can occur in the cap. Letting them charge on a low current will remove the oxidation. BTW, they are long life types as can be found here: http://www.ecomal.com/pdf/ALUCaps.pdf
It's only audio |
#6 | |
We will pay the price, but we will not count the cost... |
#7 |
I don't know why the manufacturers like to use unreadable datecodes. I don't know what to think of BA1, sorry. Maybe the datasheet explains how the BA1 datecode translates into an understandable date ?!?!
Just use the technique as described and you'll be able to use them in most cases. I never use electrolytic caps older than even 5 years in my gear but that's just me. Above 10 years is too old, I've learnt my share with caps Stocking of electrolytic caps is only interesting if they can be bought for low prices and if you think you'll be really using them in the near future. Also long life parts of MIL quality can be bought without doubt if they're new/unused and produced not too long ago. The prices of new ones when bought cleverly at the right shop is too low for wanting to use doubtful parts ( doubtful in the sense of not knowing how old it is ). Some reading on lifetime of electrolytic caps: http://www.svalander.se/shoppen/pdf/...fe_factors.pdf
It's only audio |
#8 |
thank-you for the useful informative post JP.
#9 | |
Thanks heaps for the advice and information guys, much appreciated |
| This may be good for a Gainclone kit (LM3875) | mudihan | Chip Amps | 0 | 24th August 2007 03:26 AM |
| Gainclone V+ to V- capacitor? | sharpi31 | Chip Amps | 21 | 6th November 2006 01:46 PM |
| nos-dac to gainclone coupling capacitor question | sharpi31 | Chip Amps | 1 | 15th June 2006 08:09 AM |
| capacitor brands?? good, bad, cheap, rubbish, what have I got??? | SkinnyBoy | Parts | 4 | 30th November 2003 01:42 AM |
| ELNA LP5 capacitor any good? | UrSv | Parts | 0 | 25th August 2002 04:11 PM |
| Page generated in 0.12460 seconds (80.44% PHP - 19.56% MySQL) with 11 queries |
