| Parts Where to get, and how to make the best bits. PCB's, caps, transformers, etc. |
I need 2 x 2SC3942 NPN transistors.
I cant find them in the UK and Digikey want an outrageous amount for handling/shpping. Is there an equivelant i can use? It is used as a CCS on the Hagerman Cornet2, i dont know if that affects alternatives. Any help would be much appreciated. Andy |
#3 |
Thanks,
All i could find there was a Fairchild item, but the base to emitter voltage was 2 volt lower than the specified one. Is this a problem? |
#4 |
Did it Himself
Maximum base-emitter voltage is not a critical parameter.
| Can bias transistor mount on top(body) of output transistor?? | Leolabs | Solid State | 23 | 16th February 2008 12:35 AM |
| help finding sub | chainenoble | Subwoofers | 5 | 10th April 2006 04:25 PM |
| Need some help finding these | homemade | Parts | 4 | 8th October 2005 09:17 PM |
| Help in finding Amp | chopperluf | Car Audio | 0 | 26th August 2004 02:10 PM |
| finding qes and qtc | DREW028 | Multi-Way | 3 | 27th July 2004 11:25 AM |
| Page generated in 0.06006 seconds (74.11% PHP - 25.89% MySQL) with 10 queries |
