Go Back   Home > Forums > Design & Build > Parts
Parts Where to get, and how to make the best bits. PCB's, caps, transformers, etc.
Old 7th June 2004, 04:27 PM   #1
snork is offline snork  Switzerland
Question Please help.
I found an old pioneer amp(SA-610) laying around.
It does'nt work, and when I opened it up, I found 4 blown transistors.
My problem is that I can't find the markings in the standard transistor codes.
All four transistors have 'c1914 A02g' marked on them.
My knowlege of all things electric is pretty basic, and I would like to know what those markings translate to in standard codes (I thought maybe 2s********, but I'm not at all sure.)
What could be a possible modern replacement.
A good question is also, what could have caused four transistors of the same type to blow? All the other parts seem OK, and the there are no other 'c1914' types.
Old 9th June 2004, 07:33 AM   #2
dhaen is offline dhaen  Europe
diyAudio Moderator Emeritus
dhaen's Avatar
You are probably right in your presumption: 2SC1914
Are you sure they're faulty?
Nothing special:
TO92 ecb
VCB 90V
VCE 90V
VEB 5V
IC MAX 50mA
P tot 200mW
FT 75 MHz
hfe 250 @ 1mA
Old 9th June 2004, 11:09 AM   #3
One is split down the middle, the other three are all black with the top half missing(blown off).
Do you know how something like this could have happened? I don't want to replace the transistors just to have them blow again.
Old 12th June 2004, 12:21 AM   #4
Would it be safe to test a pair of speakers once I replace the transistors?
Old 12th June 2004, 09:40 AM   #5
dhaen's Avatar
They were most probably blown because another device - one or more power tansistors have failed.
Changing these alone will only blow up another set. Sorry..
Old 22nd June 2004, 11:34 AM   #6
Hm,
Is there any way to test what the problem is?
Page generated in 0.08695 seconds (77.36% PHP - 22.64% MySQL) with 9 queries
