Parts Where to get, and how to make the best bits. PCB's, caps, transformers, etc.
DIY 40 step attenuator, anyone interested in such???
Old 7th June 2004, 01:29 AM   #11
Magura is offline Magura  Denmark
Magura's Avatar
Default Re: DIY 40 step attenuator, anyone interested in such???
Originally posted by Magura
To make such a description would take loads of time, so please take into account before answering that you will need at least a lathe and a drill press...and naturally some experience with both.
I have estimated the price for a DIY "no expense saved" 40 step attenuator to be around 100 USD for one layer, plus around 30 USD per layer of switches.
Magura
Originally posted by fdegrove
It may be a good idea to start with a list of required equipment to make such a switch?
Everything is possible....to do the impossible just takes a little while longer.
www.class-a-labs.com
Old 7th June 2004, 01:31 AM   #12
Magura's Avatar
Originally posted by tom1356
I have a 32 position Seiden I would like to replace. I'm in. The more wood in it the better.
No wood....aluminium, silver,copper and fibreglass.
Ohh, and read my last post as well
Magura
Old 7th June 2004, 02:30 AM   #13
Magura's Avatar
I finally got my first digi cam this friday, so a couple of pics is now an option.
The first part to be made is the die for cold forging the silver contact pins. The first photo is the die closed, the second is the die opened and the ejector pin laying next to.
The die is to be used in a press, or in the lack of such in a vise.
Magura
Old 7th June 2004, 02:31 AM   #14
Magura's Avatar
And the second pic.
Old 7th June 2004, 05:25 AM   #15
Brian Donaldson is offline Brian Donaldson  United States
Brian Donaldson's Avatar
Magura, I knew you had potential to do great things. I highly doubt that I would make such a fine thing, but I would greatly enjoy reading how you make one. Maybe enough other people would enjoy your tutorial enough that you may decide to do it for the glory? If you don't make a full blown tutorial on the subject, please post some pics of your work.
My uncle owned a small machine shop. I often wished he wasn't retired. I'd be his best nephew.
Old 8th June 2004, 01:30 AM   #16
Magura's Avatar
Hmm, I guess the interst in actually building a rotary switch is not there, so Ill do as Brian Donaldson proposed and make a picture thread showing the progress of the project as it happens.
BrianGT have been so generous to set me up with a gallery entry on a NICE server, Ill post better pics there.
www.briangt.com/gallery/magura
Magura
Old 8th June 2004, 01:45 AM   #17
BrianGT is offline BrianGT  United States
diyAudio Moderator Emeritus
BrianGT's Avatar
Send a message via AIM to BrianGT
Magura
Thanks for sharing your work with the forum. I am quite interested in your ideas and design.
Brian
Old 8th June 2004, 01:47 AM   #18
fdegrove is offline fdegrove  Europe
diyAudio Senior Member
fdegrove's Avatar
Same here, Magura.
Keep them coming...
Frank
Old 8th June 2004, 02:55 AM   #19
Peter Daniel is offline Peter Daniel  Canada
Peter Daniel's Avatar
DIY 40 step attenuator, anyone interested in such??? Send a message via AIM to Peter Daniel
How did you figure that interest is not there? I, for one, am very curious with what you will come up with.
I think not too many people has much experience with building such thing, so they just await your pics.
From my experience, I don't think you need anything more than 800x600 to show any detail.
www.audiosector.com
“Do something really well. See how much time it takes. It might be a product, a work of art, who knows? Then give it away cheaply, just because you feel that it should not cost so much, even if it took a lot of time and expensive materials to make it.” - JC
Old 8th June 2004, 03:05 AM   #20
Magura's Avatar
As far as im concerned there are a handfull of people on DIYaudio that are actually able to make such a thing, and none of those people have shown any interest
Im sure lots of people are curious what this is, but the interest in actually making one seems to be rather limited...thats what I meant with it, not that Im not going to make one, cause I sure will as I need a few.
As I wrote in an earlier post, the reason for asking if anybody is isnterested in actually making a switch, is that it will take a LOT of work to make drawings that are any good to anybody but myself. No reason to make such if nobody is going to actually have any need for such. Then a pic thread is less work and just as good.
Magura
DIY 40 step attenuator, anyone interested in such???Hide this!Advertise here!
24 Step Attenuator poynton Parts 1 9th January 2008 08:26 AM
23 step attenuator tryonziess Chip Amps 2 21st May 2007 01:33 PM
12 step 10k attenuator problem vdi_nenna Everything Else 2 26th July 2005 08:10 PM
Alps step attenuator kmtang Tubes / Valves 5 30th May 2005 12:51 PM
