Isolation transformers - Page 4 - diyAudio
Go Back   Home > Forums > Design & Build > Parts
Parts Where to get, and how to make the best bits. PCB's, caps, transformers, etc.
Old 6th June 2004, 12:29 AM   #31
diyAudio Senior Member
fdegrove's Avatar
Bricolo,
-the amp's transformer becomes quiet -> DC on the line (that causes the core to saturate)
Let's suppose it is DC on the line for a minute and you won't be able to keep your friends' isoxfmr. What can you do?
1/ You could buy a new one in which case I'd choose one with an EI core or better, NOT a toroidal one, with an electrostatic shield that you connect to Earth.
Chosing one with a higher current rating will have a better chance to run cooler if you're lucky. Most xfmrs heat up due to copper losses in the wires.
2/ You could build a DC blocking circuit as explained on Thorsten Loesch's website and this one:
DA BLOCK.
Watch the diode and cap polarities, follow all the necessary safety precautions and it should work.
3/ if you think of investing in an isoxfmr, think 5KVA, not 500VA if you plan to run the entire system from a single unit, otherwise use smaller rated ones where it matters most, i.e. digital naughties.
4/ Whatever you build that uses a powerxfmr nowadays will likely benefit from a well built high quality xformer. Most toroidal powerxformers could double as decent OPTs which should tell you enough to know they'll likely let a truckload of RF junk riding on the mains through as well. This is why I almost always avoid toroidal powerxfmrs like the plague.
5/ A cheap powerxfmr is a cheap powerxfmr so don't expect stellar results from it.
I haven't read the entire thread so if I repeated someones elses' suggestions, my apologies.
Frank
Old 6th June 2004, 01:16 PM   #32
Bricolo is offline Bricolo  France
Bricolo's Avatar
Originally posted by Bas Horneman
here is a link to it...it is actually quite complex with all the transformers...sorry about that......
the isolation transformer actually looks like a better option.. ;-)
http://www.diyaudio.com/forums/showt...840#post191840
the problem is that I have only one transformer, with a single primary
Old 7th June 2004, 03:51 PM   #33
serengetiplains's Avatar
Default Topaz 5KVA on eBay
Bricolo, check it out:
http://cgi.ebay.com/ws/eBayISAPI.dll...819629512&rd=1
I have a Topaz 5KVA and am very happy with it. You can run this transformer in step-down quasi-balanced mode 240VAC to 120VAC balanced. I say "quasi-balanced" because I'm uncertain just how balanced the secondary windings are.
Old 7th June 2004, 03:53 PM   #34
Default eBay II
A smaller Xentek 1KVA model is also for sale on eBay. Looks like a repackaged Topaz, but in any event gives -146dB noise reduction.
http://cgi.ebay.com/ws/eBayISAPI.dll...820308409&rd=1
Old 28th June 2004, 11:10 AM   #35
Bricolo's Avatar
I've seen an isolation transformer on ebay, relly cheap
but the picture shows a toroid
can an isolation transformer be a toriod??
Just remember: in theory there's no difference between theory and practice. But in practice it usually is quite a bit difference... Bob Pease
Old 28th June 2004, 07:16 PM   #36
Location: Auburn, WA (somewhere between Seattle and Tacoma)
Send a message via ICQ to Damon Hill
http://www.toroid.com/index.html
http://www.equitech.com/products/products.html
While I prefer my Topaz Ultra-Isolation transformer
(.005 pf interwinding capacitance), toroids with
carefully balanced windings and Faraday shields
do make for compact isolation transformers.
That's the trick: it's got to be a quality component
designed as an isolation transformer for best
isolation results. Given a toroid's inherant wideband
capability, magnetic coupling can defeat electrostatic
shielding so carefully balanced windings are necessary
for best common mode rejection.
And I can still get some dimmer buzz even through
my Topaz, at some settings on the dimmer. I need
a dedicated 220 V line, but I doubt my landlord's
going to be sympathetic to major wiring changes.
I'm also using heavy-duty Isobars, but that's because
I originally lived in lightning-prone Georgia.
http://www.tripplite.com
--Damon
Old 28th June 2004, 07:46 PM   #37
Bricolo's Avatar
There's no other info than "Isolation transformer, 850VA" on ebay
here's the picture
Free Isolation Transformers Ric Schultz Swap Meet 3 29th November 2006 09:34 PM
4kV isolation input transformers? mzzj Parts 2 24th July 2005 09:11 PM
Isolation transformers Lo-z to HI-z Roadking Swap Meet 0 5th April 2004 12:05 AM
Using isolation transformers with TT motors? Saurav Analogue Source 6 13th February 2003 06:16 AM
Isolation transformers - buzzing schpeltor Parts 8 9th September 2002 10:06 PM
Copyright 1999-2017 diyAudio
